dForce Genesis 3 Issues
Hi All,
When I try to use a dForce sheet with my Genesis 3 model, the model goes into a zero pose at the start of the animation which messes up how the sheet hangs. How do I fix this?
Hi All,
In your "Simulations Settings" pane/tab go to "Initialization" in the "Currently Used" window, then switch "Start Bones From Memorised Pose" to OFF.
Remember to change it back, when you're done.
That usually works.
Thanks, that did work! It's my first time using it.
Glad to help.
And there are several tutorial threads for dForce, for when you feel adventurous. And dForce experimenters are expanding its abilities every day.
