Star Angel won't install
I bought the new Star Angel and a few other things https://www.daz3d.com/dforce-star-angel-outfit-for-genesis-8-females I downloaded and installed them all via DIM. However, Star Angel downloaded but only goes as far as 71% installed then fails. Everything else worked fine except for that one. I am using 4.10.
    If you get a download that corrupts or won't finish then before you try to redowlad it you should clear your browser cache and then reboot the browser to make sure it has cleared before you ty to redownload.  A corrupted download can cause the computer to keep ceasing to download at the same point each time
  • galattgalatt Posts: 230
    Thanks. I will try that.
    I tried that., but ir didn't work.
