Large Address Aware app question.
StuartBStuartB Posts: 600
edited December 1969 in Bryce Discussion
I've been using the Large Address Aware app to tell Bryce to use more memory and it seems to work
as Bryce does'nt crash so often.
I would like to know if I need to run it every time I run Bryce or does it change Bryce so it knows every time.
If I need to run it every time is there a way to have it running at PC startup?
Thanks.
  • HoroHoro Posts: 11,480
    No, no need. This is a flag that is set and it stays set until you reset it - which can also be done if you got it from http://www.techpowerup.com/forums/showthread.php?t=112556. If you use the Expert mode, you see which programs are set to LAA. The picture shows my present settings.
    602 x 332 - 17K
  • StuartBStuartB Posts: 600
    Thanks Horo.
    Does that mean if I set it and exit the program it stays set, and after a reboot of the PC it stays set.
    Exactly. It will stay set (or unset) until you manually change it. Booting doesn't make any difference. If you re-install Bryce, that's another matter.
    Thanks again Horo, that's cleared that up fo me.
