Leather Mad Hatter Freebie- g8f
This hat was created with intent to be used as a free asset for artists to use in their renders. It is provided as a Daz Studio clothing item for Genesis8Female and can be easily adapted to any model. I have included the geometry in .OBJ format to do with as you please. I look forward to seeing what you will make with it.
The clothing item has been completely overhauled. Geometry clipping fixed. It is rigged as a clothing item for Genesis 8 female with transferred weights. After running a few tests it seems to conform to custom head shapes well enough that I didn't need to bother with weight painting. I was going to add morphs for hair before I realized that didn't make sense beyond some subtle stretching with a hat this rigid. Pose your hair instead :P. I still plan to add morphs for movement, crumpling, smashed, etc. Templates have been included as well as and OBJ file. Daz Iray material preset has been adjusted as close to PBR as I could manage, and textures were optimized. Enjoy!
Here is a download via Mega-link. Alternativey the file can be downloaded from my D.A. page, but I have it up as a donation option for 20 points. If at least one person could give me a heads-up that the link worked fine I would be grateful.
https://mega.nz/#!cuwHHbrL!FPYS5vimh0m555zKYbbOu_yacYJzZ1Nw42cE-5zB3zE
It worked. Thanks.
A Quick render.
Oh! That looks cool. Thanks for sharing :)
thank you for the nice hat
if loading with people/clothing
i get missing file in E:/Blender
would be nice if there were some predefined movements getting the hat more into the neck or front or side
Thank you for taking the time to respond Ruphuss. Some adjustment morphs will be included in the final update. The next update will use the same files so no need to reinstall as with the alpha. Could you by any chance list what file or screenshot is calling for the E/blender structure? That sounds like I might have missed a texture map, the old version lived in a production folder.
Also, nice render :)
missing files
e:/blender resources/!ab blends/!clothing/hats/hatter_subs/leather_blackred/brim_glossiness.jpg
e:/blender resources/!ab blends/!clothing/hats/hatter_subs/leather_blackred/hatter_top_roughness.jpg
e:/blender resources/!ab blends/!clothing/hats/hatter_subs/leather_blackred/lace_height.jpg
e:/blender resources/!ab blends/!clothing/hats/hatter_subs/leather_blackred/stripe_inner_glossiness.jpg
e:/blender resources/!ab blends/!clothing/hats/hatter_subs/leather_blackred/stripe_inner_height.jpg
e:/blender resources/!ab blends/!clothing/hats/hatter_subs/leather_blackred/stripe_inner_normal.jpg
A Quick render.
I got a notice about missing textures in DS but was able to locate them manually
Here is the update as mentioned. It includes a fix for the missing texture map error, as well as a bunch of basic morphs for adjustments.
http://mega.nz/#!0jpWkAgI!LP71kwokzklJSFGcupEiVIxkVs-NIxeIsCjfSgcGwFM
hey that was quick
still get the blender files message
Here is another update! I hope you don't mind I add content with each one... ;) This update fixes the single texture map missing error that escaped the last fix, as well adding 3 more color options , the hat as a handheld prop, with one chorus line pose.
https://mega.nz/#!p6hHCAxZ!H_6YhX8R6Z3mJbYyXBNW4_RoD1xnKrDDDmyRy4f5OOA
installed over the top
i do not know how to clean all files deep in the systems
there were times where we got uninstallers with products but that was before DIM and connect
the link goes back to 1.5 version
intended ?
If you click the deviantart link then you can find the update on the main page in the picture on the right, just click read more to show the link.
Thank you Ruphuss for your continued patience as I get the hang of how all this packaging and publishing content works, and what to avoid. Also thank you Faeryl Womyn for helping out. Actually the aforementioned 2 links are both outdated. I ran out of time last night to post version 1.7, and I suppose working after the day job until the small hours of the night all week might help some things slip notice. Overwriting the files should work just fine post 1.5, but I did notice data files for some older geometry got left in the earlier packages, which is why I suggest cleaning that out. It's not mandatory to use the item since the presets and props have all been updated, that's just my OCD on the matter here.
Anyway, here it is.
Got the new version, will try it out tomorrow.
Great let me know how it works out. I'm taking off this weekend from projects but I still check messages.
this is left
the hat works all fine though
thank you
