Oso Master Shader1 for Iray [Commercial]
13»
  • Hurdy3DHurdy3D Posts: 1,076
    Hey Oso3D,
    I got this prodcut yesterday, but for DAZ3D beginners it's a little bit hard to understand. It would very helpfull if you could update this product and attach a PDF manual with 2 or 3 examples.
    Is it intended that the shaders don't appear in the smart content as a product?
  • Oso3DOso3D Posts: 15,104
    The readme was not included in the product for some reason (I hope to have that fixed shortly).
    It's not a PDF with examples, but hopefully it will help you out!
    txt
    txt
    OMS1 Readme.txt
    6K
    OMS1 has been updated to include a pdf readme.
    Please update at your convenience.
  • scorpioscorpio Posts: 8,533
    Thanks answered my question before I could ask it, I saw it had been updated and wondered why?
  • galiengalien Posts: 148
    This is crashing the latest 4.12 Beta version of Daz Studio whenever I try to do a render.  It works ok in DS 4.11.
    Before I raise a support ticket, is anyone able to do a render using this shader with Daz Studio 4.12?
  • FishtalesFishtales Posts: 6,228
    It works on Studio 4.12, I haven't tried it on the beta though.
    edited November 2019
    Just tried it on the bet 4.12.1.16 and it shuts it down a few seconds after I loaded the shader. There is nothing in the log to suggest a problem other that where it says Rendering at the bottom Studio is unresponsive and nothin that I clicked on responded and there was no Studio Isn't Responding warning.
    LOG
    2019-11-04 14:10:34.116 Loaded file: oms1 base droplets.duf
    2019-11-04 14:10:34.360 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating geometry.
    2019-11-04 14:10:34.360 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing scene graph.
    2019-11-04 14:10:34.361 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Importing geometry for motion time 0
    2019-11-04 14:10:34.450 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Geometry import (1 object with 19980 triangles, 1 instance yielding 19980 triangles) took 0.088s
    2019-11-04 14:10:34.450 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating materials.
    2019-11-04 14:10:34.452 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : Material instance 'DS_Rock-20__default_308_31' uses MDL JIT compilation.
    2019-11-04 14:10:34.453 Iray [INFO] - MATCNV:RENDER ::   1.0   MATCNV rend info : found 7 textures, 3 lambdas (3 unique)
    2019-11-04 14:10:34.458 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating lights.
    2019-11-04 14:10:34.459 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating object flags.
    2019-11-04 14:10:34.459 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating caustic portals.
    2019-11-04 14:10:34.459 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Updating decals.
    2019-11-04 14:10:34.462 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Allocating 1-layer frame buffer
    2019-11-04 14:10:34.464 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Using interactive scheduling, caustic sampler disabled
    2019-11-04 14:10:34.470 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2019-11-04 14:10:34.470 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce RTX 2060)
    2019-11-04 14:10:34.470 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    This is the same part of the log file from Studio 4.12.0.86.
    It stops in the Beta when Optix for CUDA is being called.
    LOG
    019-11-04 14:23:34.584 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 1 device(s):
    2019-11-04 14:23:34.584 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : CUDA device 0 (GeForce RTX 2060)
    2019-11-04 14:23:34.584 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
    2019-11-04 14:23:34.585 Iray [INFO] - IRAY:RENDER ::   1.42  IRAY   rend info : Initializing OptiX for CUDA device 0
    Post edited by Fishtales on
    Thanks for checking this out Fishtales.
    It's good to get confirmation that it isn't something specific to my system.
  • rrwardrrward Posts: 556
    Oso3D said:
    Let's not have that fight here. ;)
    Anyhoo, this is kind of a weird render, but it highlights something I'm very happy about and proud of in this product, which is the ability to have fairly convincing smoke and cloud effects. Where this exceeds other attempts is the procedural displacement, which helps create that rippling effect, plus some variation in refraction to capture more surface qualities to give it dimension.
    Anyway, here you go.
    Great googly moogly!
  • JhudJhud Posts: 33
    Well I purchased this and I wait with fingers crossed for someone to upload the video showing the beauty of how this works. I have printed out the pdf file, all three pages to use as a reference. Problem is I am drawing a blank because there has been nothing posted to tigger my brain cells into trying this. So if someone does a video tutorial I would really be a happy camper. wink
    Well, a good place to start is simply trying out some of the presets.
    The cloud and smoke presets are fun to play with, maybe some rocks... find something monstery to use with the more glowy presets.
  • CedworthCedworth Posts: 14
    I quite like this shader, I see a lot of potential with it.
    I've got this grommetted leather belt material started.  However, I'm trying to get the bump off of the overlay part (the metal grommets).  It looks like the overlay bump strength slider isn't doing anything.  The base bump strength seems to be controlling both layers' bump.
    Here's what I mean.  The first has bump at 1 and overlay bump at zero and the bump is on both layers.
    The second one has bump at zero and overlay bump at zero, and looks as expected.
    The third has bump at zero and overlay at 1 and it looks the same as if both are zero.
    1129 x 744 - 468K
    1189 x 774 - 257K
    1294 x 718 - 429K
    Post edited by Cedworth on
    Huh. I'll look into it, thanks.
    I'm still planning on a fix for this, just so people know.
    I'm just buried in one of the biggest projects I've ever worked on (basically, 4 products planned as a bundle. eeep)
  • I have all your shaders, and they're all indespensible, so I'll be adding this one to the collection as well.
  • jardinejardine Posts: 1,220
    no hints?
    sigh...
    Male and Female anthro, with addon for each.
    It's... ambitious as heck. Mmph
    you do seem to do pretty darn well with ambitous off-the-beaten-path projects.  it's kinda your deal, seems to me.  :)
    anyway, i will await this one with great interest and curiosity.
    good luck!  and thanks for the hint.  :)
  • GordigGordig Posts: 10,700
    Is it too much to hope for that they would be your namesakes?
    Ok, sorry this took so long to get back to, but looking more carefully...
    Yes, the Overlay Bump Strength doesn't seem to be working, which is annoying. On the other hand, I'm not sure it matters?
    Bump Strength will essentially determine how high/low the Base level is compared to the Overlay level. You can set that to any value; the only thing that would matter is the difference between the two values. If you just consider Overlay Bump Strength set to 0, then all you really need is different levels of Base Bump.
  • @Oso3D I'm a bit confused on how to use the product (I did see the readme in the forum, which I didn't see with the product). In Daz 4.14 I see some things under Shader and the rest under lost and found. The shaders seem to be the underlying white/black maps and the lost and found seems to be colors. For the most part if I try to apply the colors (OMS flame for example), or even alot of times when I apply the shaders then color it usually crashes. I tried to use Daz Dragon 3 because the promos used it to reduce variables. I literally have nothing else in the scene. Sometimes it in very rare instances if I apply the shader first then color it might sort of render. But I still don't understand how to really apply them the way you are explaining in the thread.
    I think it might help to explain a step by step example. For example in the very first picture in your promo, the guy with molten lava hands and legs - what exactly would you do to a model to arrive at that molten lava look?
    I really like your stuff btw especially the pixie dragons!
    Well, if you click on a surface and apply the preset, bam, there it is.
    For the guy with molten lava hands and legs, I put a mask in the Overlay luminance so that it only glowed at the extremities.
  • @Oso3D I do apply the preset to a specific surface (like skin surfaces) but most of the time it ends up crashing?
  • Well maybe I just needed a restart, it doesnt seem to be crashing any more? Weird
