G3 anatomical elements seam
daveso
I added the anatomical element to G3..image attached. note the seam.. you can tell the textures matches, but the object appears to be a bit larger than the body or something?
How to correct?
Are you sure they are using matching materials (both 3Delight or both Iray)?
both iray I'm pretty sure. i will give it another go in a bit to be positive.
Not sure this is the issue here, but make sure you’re not in geometry editor mode, as that makes geografts look funky.
Yeh, what Redz said; if you look carefully at the seem; the geometry doesn't have a smooth seam; it's that not texturing - going off the image; could do with being larger and higher res.
Certain body morphs won't line up properly with the anatomical elements if the morphs to the area were not done with the gens attached.
Whenever that happens to me, it's usually a difference in the displacement or subsurface shading or maybe translucency. I usually find it by comparing the two surfaces line by line, setting by setting. It's tedious, but that's usually where I find the problem.
I can't tell from the pic if the mesh is separated there--like a pelvis shield that hovers too high over the original body mesh--or if it's just a difference in coloration. If it is just a difference in coloration, I think Kitsumo is probably right: there is some small difference in the shader settings between these two surfaces.
Because there are so many details to look at, what I normally do is:
In other words, I'm lazy: I'd rather just wipe out the bad setting than laboriously track it down.
Hi, daveso I've run into this problem and it had to do with sss and some other shaders that were not avalible in the geograph. I tried to copy and paste the shaders in the main torso over to the geograph in the shader tab. This did not work. The only thing that works is to start from scratch and use a simple Iray shader and add it to both the main character and the geograph and tweak the setting to match for both. This is a serious issue that there is no easy fix for. We could use a script that copies the shaders and creates genital textures from the main textures (not all content creators provide genital textures). I hope this helps
thnks for all the help. it helps
I find that squaking like a bird at my computer screen helps occasionally.
I've seen that problem with Genesis 8 too and it went away 100% when on a hunch when I changed the skin shader materials to use Mono instead of Chromatic.
