Hornet for Genesis 8 On Sale Now! [Commercial]
2»
  • AntManAntMan Posts: 2,181
    So here is an update, I have been working with my testers and no else is having this problem, or able to make it happen on their ends. I know as long as you are it's real. The suggestion was to use DIM to uninstall and re install the package. It was also ask if you were using the latest Studio Build. I am glad you have it working but could any of this help?
    I often ask "how can this just be happening to me!" and people reply I have no idea. I'm trying to do you one better, but they assure me all is functioning correctly.
  • ArtiniArtini Posts: 10,974
    edited March 2018
    I have downloaded it (IM00050891-01_HornetOutfitforGenesis8Females.zip) once again,
    but the "space" in file names for pants remains.
    I have unzipped downloaded file and below is the image of textures folder,
    where it clearly shows "space" in file names for Hornet Pants.
    Of course, the testers are always right, so it is only fault on my side.
    I am glad, I have fixed the issues myself, so I can use your product.
    I understand, that fixing the names require some additional work from your side,
    and you will not want to spend your time on the issue, that no one else complained about.
    780 x 471 - 165K
    Post edited by Artini on
    I have checked the "File List" for your package on:
    http://docs.daz3d.com/doku.php/public/read_me/index/50891/file_list
    and there are underscore instead of "space" listed there:
    • /Runtime/Textures/AntFarm/Hornet/Hornet_Pants_Base_Color.png
    • /Runtime/Textures/AntFarm/Hornet/Hornet_Pants_Height.png
    • /Runtime/Textures/AntFarm/Hornet/Hornet_Pants_Metallic.png
    • /Runtime/Textures/AntFarm/Hornet/Hornet_Pants_Normal_OpenGL.png
    • /Runtime/Textures/AntFarm/Hornet/Hornet_Pants_Roughness.png
    edited March 2018
    I dug deeper with a Daz Tech, he said there was a DIM issue. So I was misinformed. They did however fix the issue so if you were to download it now I think the issue has been fixed.
    So it's good to keep digging at the issue. Let me know if we get it right, and then, I will be able to sleep soundly. And thanks for the input and your patience.
    Post edited by AntMan on
    I have checked again, but the files are the same as yesterday.
    I will check again tomorrow and see, if there are any differences.
    Thanks!
    edited March 2018
    Now, all issues are fixed. Great work.
    1600 x 1080 - 256K
  • One issue I've noticed, and I'm seeing it in Artini's render as well, is that the pants do not automatically conform to the figure like they should.
    edited March 2018
    It all depends of which character one choose to wear Hornet clothes.
    Below is an example render of Daphne - https://www.daz3d.com/daphne-for-olympia-8
    The pants fits much better to her, but I agree,
    that the utility morph for adjusting waist on pants would provide much more flexibility to the set.
    1280 x 1080 - 186K
  • Steel RatSteel Rat Posts: 417
    edited November 2021
    Major pants issues here:
    865 x 865 - 3M
    Post edited by Steel Rat on
