Super Firefly: Artifacts and seam lines?
TeloxiTeloxi Posts: 21
edited March 2018 in Poser Discussion
This is my first attempt letting Super Firefly render completely without hitting cancel. It was looking so good till I saw....what I hadn't seen before. Look at the right shoulder and you can see lines and odd dark areas that shouldn't be there. Attached is the render (cropped due to nudity) as well as render settings and the values for both lights used. I'm using an acer laptop with 4gigs memory so render settings have to be a bit conservative. Can anyone tell me what happened and how I can reduce the strange issues I encountered?
Post edited by Teloxi on
  • S RayS Ray Posts: 405
    Looks like a low level polygon problem. If you look real close you can actually see the shape of the sub-D loops and the dark spots are one of the 2 triangles that make up the loops.  Does that figure support sub dividing on the body parameters?
