Is there a way to find if a morph has been ERC frozen or not?
Is there any way to quickly and easily tell if a Morph has been ERC frtozen or not and is there a way to undo it?
    Yes and yes.
    Search the morph's name in the Property Hierarchy tab.
    look under Sub-Components and Controllers.  If it's been ERC frozen, there will be entries under one or both.  Sub-Components are controlled BY a morph; Controllers control the morph.  Deleting any of these entries under Controllers or Sub-Components breaks the ERC link.
  • agent unawaresagent unawares Posts: 3,513
    edited March 2018
    The absolute quickest way to check is to just hover over the parameter. If a little link icon appears up top, there are ERC links. But if you want to change stuff you have to go into Property Hierarchy as SY said.
    Post edited by agent unawares on
  • Richard HaseltineRichard Haseltine Posts: 109,532
    If the Parameters pane is in Edit Mode (via right-click) then you can also right-click on the morph and select Show in Property Hierarchy
