Dreamlight Eternal Romance for Village Courtyard Question
ravvenkitsuneravvenkitsune Posts: 77
I'm unable to load the main lights for this scene and I was hoping that someone would be able to help. I install everything through DIM and this one seemed to install correctly, but the main lights might be missing, or the path is incorrect? Everything else loads. I would give anything for basic documentation on this type of product! :)
Thank you.
If it helps, this is from the log file:
2018-02-28 11:00:52.726 Building Scene...
2018-02-28 11:02:25.582 Merging file MainLights.daz...
2018-02-28 11:02:25.873 Unable to find file for storable: data/pPlane(11cg000)1/shape/maps/uv.dsv
2018-02-28 11:02:25.874 Unable to find file for storable: data/pPlane(11cg000)1/shape/uvs/default.dsv
2018-02-28 11:02:25.874 Error loading storable: C:/Users/Public/Documents/My DAZ 3D Library/data/3_0/pPlane(11cg000)1/shape/geometry.dso
2018-02-28 11:02:25.877 Unable to find file for storable: data/pPlane(11cg000)1/shape/maps/uv.dsv
2018-02-28 11:02:25.878 Unable to find file for storable: data/pPlane(11cg000)1/shape/uvs/default.dsv
2018-02-28 11:02:25.880 Error loading storable: C:/Users/Public/Documents/My DAZ 3D Library/data/3_0/pPlane(11cg000)1/shape/geometry.dso
2018-02-28 11:02:25.884 Unable to find file for storable: data/pPlane(11cg000)1/shape/maps/uv.dsv
2018-02-28 11:02:25.885 Unable to find file for storable: data/pPlane(11cg000)1/shape/uvs/default.dsv
2018-02-28 11:02:25.885 Error loading storable: C:/Users/Public/Documents/My DAZ 3D Library/data/3_0/pPlane(11cg000)1/shape/geometry.dso
2018-02-28 11:02:25.889 Unable to find file for storable: data/pPlane(11cg000)1/shape/maps/uv.dsv
2018-02-28 11:02:25.892 Unable to find file for storable: data/pPlane(11cg000)1/shape/uvs/default.dsv
2018-02-28 11:02:25.892 Error loading storable: C:/Users/Public/Documents/My DAZ 3D Library/data/3_0/pPlane(11cg000)1/shape/geometry.dso
2018-02-28 11:02:25.903 Unable to find file for storable: data/pPlane(11cg000)1/shape/maps/uv.dsv
2018-02-28 11:02:25.904 Unable to find file for storable: data/pPlane(11cg000)1/shape/uvs/default.dsv
2018-02-28 11:02:25.904 Error loading storable: C:/Users/Public/Documents/My DAZ 3D Library/data/3_0/pPlane(11cg000)1/shape/geometry.dso
2018-02-28 11:02:25.909 Unable to find file for storable: data/pPlane(11cg000)1/shape/maps/uv.dsv
2018-02-28 11:02:25.910 Unable to find file for storable: data/pPlane(11cg000)1/shape/uvs/default.dsv
2018-02-28 11:02:25.910 Error loading storable: C:/Users/Public/Documents/My DAZ 3D Library/data/3_0/pPlane(11cg000)1/shape/geometry.dso
2018-02-28 11:02:25.915 Unable to find file for storable: data/pPlane(11cg000)1/shape/maps/uv.dsv
2018-02-28 11:02:25.916 Unable to find file for storable: data/pPlane(11cg000)1/shape/uvs/default.dsv
2018-02-28 11:02:25.918 Error loading storable: C:/Users/Public/Documents/My DAZ 3D Library/data/3_0/pPlane(11cg000)1/shape/geometry.dso
2018-02-28 11:02:27.031 File read time: 0 min 1.3 sec.
2018-02-28 11:02:27.246 Building Scene...
2018-02-28 11:02:32.850 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
2018-02-28 11:05:53.567 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
Post edited by ravvenkitsune on
  • Those are presumably primitve planes with an emissive shader applied - unfortuantely that means you can't recreate them, unless you havea  copy of DS 3 (and even then, I'm not sure how easy it would be to guess the needed settings). please report this to Technical Support https://www.daz3d.com/help/help-contact-us
  • Ah, okay. That makes sense. I wish they'd say on the product page that it will only work in an older version of the software. :( Thank you very much for responding though, I appreciate it.
  • LeanaLeana Posts: 12,987
    All Dreamlight items which say they use "Light Dome Pro" tech and don't list DS 4.x as compatible software but only "DAZ Studio" are likely to have problems in DS4 as Light Dome Pro was never updated past DS3 (Dreamlight created "Light Dome Pro - R" for DS4 but it's quite different from the original LDP)
  • Ah, so not just primitives. Thanks, Leana.
    Ah, I'll have to remember that, thank you! :)
  • LindseyLindsey Posts: 2,012
    I didn't have any issues loading this Dreamlight product by loading the !all_lights_cameras.daz preset.
    I install all of my DAZ content via Daz Connect. The pic shows the Data folder contents and the pPlane(11cg000)1 with it's associated files is at the top of the list. If you installed with DIM, have DIM show you the installed files and see if that folder was installed.
    I've attached a pic of the files DAZ Connect installed showing it's data folder contents and a picture generated with Cam 3
    1119 x 654 - 289K
    1202 x 672 - 497K
  • Thank you, Lindsey, I appreciate that. I can browse to it from DIM, and see the files associated with MainLights which I think are in the right place - not sure why it gives me this error message, though. Shame, love the image that you attached!
