create a standalone morph of a tweaked facegen dsf morph
hey guys, I use facegen to create morphs but they are obviously not perfect out of the box, so I tweak those morphs manually in daz with morph addons. I tried to save it as a morph asset, but the asset relies on the untweaked facegen dsf file and my morph addons. I just want to create a morph that everybody could use without those addons or the facegen dsf file, if you know what I mean. I want to create a clean library and if there is no way to save those morphs as standalone ones, it´s just a bit messy in my opinion. I haven´t found an option to save those tweaked morphs as a complete standalone morph. Is it possible to save those morphs as a new dsf file?
okay, found the soultion in the meantime - thread can be deleted
or for people with the same problem
here you go: https://www.daz3d.com/forums/discussion/57500/how-to-save-a-single-redistributable-dsf-morph
We don't delete threads like this. What we do suggest is that you edit the title of your thread to add (solved) to it, then other people having the same problem can see your solution.
