GenX and GenX-2
This may seem like a stupid question, but I own these two products, yet have no idea how to find them or start using them. Any hints? I didn't see anything in the content mentu, or under "tools" where some such things (like Garibaldi Hair) live.
Assuming that the utilities were installed correctly, you can locate them under Window > Panes (Tabs) > GenX. Clicking on the latter will open a popup menu. GenX2 is merely an addon for GenX, so it won't appear as a separate item. You will need to read the documentation for instructions on how to use the GenX interface correctly.
you can normally open those as a new tab, perhaps those plugins do not work in the newer daz versions. but anyways, you should check if your plugin is installed and working with help > about installed plugins, should be list
GenX 2 is the latest version. Do not try to install both GenX and Genx 2.
Oh, that might be my problem! I think I have them both. Thanks, everyone!
