Old but Goodie except??
Well I went out and got Wear them All and then fitted Fabiana's old A3 Dryads duds to G3 Gwenli and did a bunch of stuff to it but as you can see in the image below I have these pointer and can't figure out how to get rid of them. They are part of the Dryad dress but when I drag them they move the dress and gwenli. If I was in Poser I would know how to get rid o them but nothing I try here works. What am I missing.?
    edited February 2018
    Look for "handles" or something similar in the dress's materials and set opacity to 0. You could also look to see if there's a bone associated with them and then hide those bones. Look at the dress's parts in the scene tab.
    Laurie
    Post edited by AllenArt on
  • TaozTaoz Posts: 10,320
    Like AllenArt says.
    They usually don't (never?) work in DS if you try to drag them, I think that's a Poser only feature, but if you select them you can usually control them using some parameter dials instead.
  • NorthOf45NorthOf45 Posts: 5,827
    If you mean they are hyper-sensitive and jump around madly when you try to drag them, you can easily tame that. Use the ActivePose tool and select one or more handles. Go to Tool settings and you will see a new section called "Selected Bone Stiffness Properties" (only appears when a bone is selected). Slide the knob more to the right to make it/them stiffer. This will slow down their behaviour, so you can adjust it to a manageable level. Not all handles are the same, some have 1.0 default, others 0.01 (minimum) or some other value. Max is 200, so you have quite a range to play with. Not sure if it is persistent across loads. (Of course this works on any bone in a figure, but handles seem to need the attention more often.)
    Handles work in Studio however they are custom bones that get stripped out by Auto-Fit.  In addition to Wear Them All you should get Sickleyield's templates
