how do i access the light grey objects in bryce 7
edited December 1969 in Bryce Discussion
Hello, my name is Frank and i 'm having a problem with Bryce 7.
I've created a fabulous spaceship, but there are a few points i 'd
like to improve.
To my surprise i can't access the light grey objects i have created.
Can anyone tell me what i 'm doing wrong?
  • HoroHoro Posts: 11,433
    I'm not sure I get you right. You select an object by clicking on it in the wire frame. If there are more than one object at the same space, hold down the ctrl key. At the bottom, there are the thumbnails of the objects, which you can click on and get a list from which to select. And then, there is at bottom right next to the families the mesh and group selector - and of course, the families.
  • StuartBStuartB Posts: 596
    You can also use the Tab key to select objects 1 at a time.
  • David BrinnenDavid Brinnen Posts: 3,136
    Might also be that some of the objects are locked for some reason, so what you can do is use select all and uncheck the radio button which controlled locking in the Object Attributes.
    271 x 394 - 28K
    415 x 378 - 42K
    390 x 259 - 29K
    362 x 277 - 29K
    312 x 175 - 17K
    @fs.ursem - you might also have another display mode than Wireframe selected. If so, change it as shown.
    362 x 400 - 30K
