why does a data folder appears on Desktop?
WilmapWilmap Posts: 2,917
I updated to DS4.6 last week, and after using Maclean's Room Creator yesterday, I have a data folder suddenly appear on my desktop. Inside the folder is another folder named auto_adapted, and inside that are lots of folders for items I've used and they contain dsf files and morphs.
Why has it suddenly appeared and what do I do with it.
The items I used are stored on an external drive if that helps.
  • fixmypcmikefixmypcmike Posts: 19,724
    If you go to Edit > Preferences > Content Library > Content Directory Manager, is your Desktop listed as a DS-format content folder?
  • WilmapWilmap Posts: 2,917
    Just checked and yes it is.
    That would do it -- when you autofit an item to Genesis it creates the Data files in auto_adapted.
    edited May 2013
    So do I need that reference in the Content manager? Can I remove it?
    I wasn't using Genesis at all.
    I have the same folder in the data folder in My Library.
    Post edited by Wilmap on
    You could merge it with the one in My Library and remove the desktop from the list.
    OK thanks, will do that.
