Gotozbrush plugin does not load
I have Daz Studio 4.10 and ZBrush 4R8.
In Daz Studio, the "Go To ZBrush" item in the file menu is missing.
In the "About Installed Plugins" Dialog I see a red icon for dzgoz and the message is
"Version: 0.0.0.0"
"Reason: Plug-In was made for a newer version of DAZ Studio"
Can somebody tell me how to get this to work?
Which version of daz studio are you using - Help>About Daz Studio
@Richard: Thanks for taking an interest. Im using 4.10.0.107 Pro 64bit.
The version of GoZ that works with your version is V 1.6.4.117 and was installed with your version of Daz ( 4.10.0.107 )
you can re-install daz and it MIGHT work for you ( If you manage to completely uninstall the version of GoZ that is installed which is not a easy thing to do ) - if you download the plugin at daz the current version of GoZ is 1.7.0.123 and will not work with your Daz version it is only for the most current version of Daz... does any of that make sense?
I'd recommend you update Daz to the currrent version that supports the version of GoZ you have installed.
@davegv: I feel stupid for not realizing my version of Daz Studio was not current! But then there seems not to be any "check for updates" command, let alone a notification that I should update..
Updating Daz Studio solved the problem, thank you indeed!
