a guitar lead
WendyLuvsCatz
click for video
anyone can have, no restrictions, I just like creating and learning things
even one I stuck on ignore for dissing me in another thread
I am not sure how well it will work for others but it is free and you can modify it and redistribute it as much as you like
updated to fix duplicated formulas
https://www.daz3d.com/forums/uploads/FileUpload/8d/a84249adb030b170797c5a31790c36.zip
Thanks! This is very useful. A strap that functions in the same manner would be much appreciated.
Thanks for sharing. Downloaded and tested works with DazStudio v4.10.0.123.
I see you got the IK-chain thing setup with general weights - is it possible to have the same behavour with TriAx weights?
You saied no restrictions, I've edited a few things and if you dont mind I like to share an updated version. There is some minor issue with the weightmap I have fixed.
I also used ERC-Freeze and created a PoseControl Property (Morph-Slider) its simply a slider for posing - to have this cable laying around rolled up - see the render.
The Weightmap Editing I did
thanks yes you can share, I am not very good at DAZ studio rigging as I am a Carrara user and could and did easily rig it there
I actually imported it into Poser then D|S and converted to weightpainting and smoothed it as was all kinky, I really don't know all the ins and outs
it was an exercise for me to try and get Carrara rigging into D|S and started from a query by Diomede on the Carrara forum about getting his custom figures in,
I chose the lead as had a bit of flack in another thread from someone who wanted to make one over my Carrara fandom so I decided to rather than speak to that person further about their personal attack on me and get my post removed, just try and take the higher ground and make one myself.
I have characters in a band so could prove usefull in my animations.
your workflow will prove helpful as I had no idea how to smooth all the bones, it actually imported each 100% hence the kinkiness and I had posted a thread on that but semi solved it by manually painting smoothing on each bone which was a bit hit and miss, I did not know a faster way until you posted that.
duplicate
Thank you. Nice lead and nice job. Thank you for sharing.
Looks like you made the guitar lead a few years ago but I'm new to Daz and just found it today. It is the perfect solution to my problem today, I needed 6 identical flexible cables for one image and hated the idea of spending almost $20 for a single use. I'm not using it for a guitar but I don't think you'll mind too much! Right now your guitar lead is plugging a robot into a charging device. I suspect I'll be using your guitar lead again in the future, thanks!!
