Awkward. Embarassing. But is there any way to fix this?
posecast
I bought SY V4 to G8 clones, but the results didnt look as good as this method. But it still needs help, especially the center and sides.
1) auto fitted top and bottom to g3f.
2) saved as wearable.
3) autofitted to g8f.
4) added smoothing modifier
5) played with collision, smoothing, and scale
What I ended up with is better than the default attempts with the SY Clones, but can anyone tell me how to specifically make it so that the center of the top doesn't wrap to the sternum, but crosses the gap in a straight line? I have zbrush but I dont know how to use it, but would love to if it will help this fix.
Thank you!
Post edited by posecast on
Scale the breast down to a more realistic size for that bikini or buy or make a bikini that would actually support breasts that size.
lol. i knew that was coming.
I can't promise you any of these will work for what you need, but three suggestions
1) Fit Control by Zevo ( https://www.daz3d.com/fit-control-for-genesis-8-female-s ) Different versions available
2) Try to fit to an article of clothing that doesn't sink/conform in given area ( https://www.daz3d.com/i13-3-stylish-tops-for-the-genesis-3-female-s ) like the light blue shirt in this promo
3) Use a dformer and try and pull the strap back out manually
*edit* 4) If all else fails you could possibly use the geometry editor (group the problem area) & hide under materials. Then add a primitive to serve as the strap and manually apply the desired texture.
Hope that helps
@Sickleyield has products for this also
https://www.daz3d.com/sy-clothing-breast-helper-genesis-8-female
https://www.daz3d.com/sy-universal-breast-helpers-genesis-genesis-2-and-genesis-3-female-s
I use hers as much as I use Fit Control (I have both and they're both useful).
These plus fit control usually work 98% of the time. Its more difficult given the size of the breasts and the size of the bikini.
I think the first thing I'd try is dForce and use a timeline, going from regular breasts to torpedos.
...and if the cloth explodes, the torpedoes did their job.
scnr
(Milk out the nose!!! ROTFL)
Laugh out loud really
heheheheh
use a dformer to move what passes for a bikini top (
) to a more appropriate postion; although considering the size of the bikini she's wearing, I doubt she cares.
Ok I laughed, Seriously you can also use deformers in Daz. They are like Poser magnets just don't work as well. Go to youtube for tutorials on how to use. This will get the string pasted to her skin to be in a more natural position and deformers will also let you move the stickies (triange patches covering sensitive parts) around. The alternative which works better is to output the model as a obj with the torpedos in tact (hahah) and use a modeler to fit the non autofitted cloth to this model. This works better than deformers. Sickleyeld has a tutorial on how to do this in the Blender modeler which is free.
