Rotating texture maps?
Hello!
This might be a very "noobish" question, but it bothers me...
Is there a possibilty to rotate own texture files 90° in DAZ Studio, or is the only way to go back to hexagon and change the hole UV-Map?
  • SimonJMSimonJM Posts: 6,081
    Pick the LIE option from the drop down list next to the image in the Surfaces tab, you'll be able to rotate the image in 90 degree increment and/or flip horizontally and vertically.
  • macleanmaclean Posts: 2,438
    An easier way to flip textures horizontally or vertically is to set Horizontal/Vertical Tiling to -1. But rotating a texture 90 degrees is usually done in LIE. It *can* be done in Surfaces, but you need to go into Shader Mixer and add the appropriate bricks. I can give you the details, but it's not for the faint-hearted. Also, the rotated texture is only visible in the render, not in the viewport.
  • Thank you very much!
  • manekiNekomanekiNeko Posts: 1,450
    .. used ds for years, didn't know this >_< thanks a lot for this useful info!
