Gades for Genesis 8 male
2»
  • nonesuch00nonesuch00 Posts: 18,856
    I'm wondering if another product is the cause because I have no such problems with Gades. Example, there is one product in the DAZ Store that customers repeatedly come to the forums asking how to fix the very botched up shoulders that product causes. That product causing the botched solders should be fixed. Odd thing is that products it causes causes problems in many other products. I'm thankful I haven't bought that product because it still isn't fixed.
    Likely, if Gades is causing problems you should file a ticket with DAZ support describing how to replicate the problem if you can.
  • So if you dial in Gades to something like 30%, then use the pose controls for the eyes and use the side-side dial, they move horizontally instead of being offset by different angles? I haven't noticed a shoulder issue that I have noticed, and I thought the last shoulder thread was about a G3M product.
    Unfortunately I dont have the product to test or I'd look at it. I'm still however waiting for the snaggley teeth to be fixed on the muscularity product.
    edited February 2018
    Yes. That's correct, no wierdness with the eyes at any scale of the Gades character morph.
    The shoulder issue is not for Gades but a older product thhat affects other producs too. It shows up from behind in the hind part of the arm pit & shoulds a big indentation. I've seen at least a dozen people asking for help how to fix it in the forums.
    Post edited by nonesuch00 on
  • FSMCDesignsFSMCDesigns Posts: 12,854
    scorpio said:
    Thanks that does seem to solve the problem, but if I alter the Gades dial then I have to do it all over again rather annoying. I don't think I have any other morphs that require this. Its a bit short sited of a PA to think that the morph will only be used at 100%; part of the beauty of the Genesis figures is the ability to mix.
    Unfortunately there are a few PAs that feel it should be all or nothing. I don't think I have ever used a PA character morph at 100%
    Post edited by FSMCDesigns on
    All or nothing characters are fine but they should never be numbered gene pool characters.
    could select the eyes and manually pose them with rotate parameters
    I'll file a ticket tonight, but just in case others were curious, no, the rotate parameters will also be off, and using the up/down rotation adjusts the eyelid by default, so it's either a lot of work to disable or manually change things, or the adjustment from the previous page. Unless there is a separate trick for that shorter than the other fix. But it isn't just that the side-side control that adjusts both eyes is off.
