What am I doing wrong???
Okay... set up a single light source. was working with some complex stuff in post... when I hit render, the light source isn't showing up, and the I am getting lights from out of nowhere... that are not in the scene set up... I have attached pics. The dark one is how the lighting is set up... the one in that is not dark is what is rendering...
WTH???
  • Hurdy3DHurdy3D Posts: 1,076
    Hey,
    if you are rendering with iray check in the render settings on environment if the environment mode is dome and scene. (if you want a transparent BG set Environement map to none).
    The lights you are adding in iray need a silly high Luminous Flux (Lumen). The default value for this parameter is around 1500. Set it high, very high (100.000 up to x.000.000)
  • KaribouKaribou Posts: 1,325
    If you're saying that the Iray image is too bright, then set the environment intensity to 0.  Also make sure that you don't have headlamps on -- check both your render settings and your camera for that.
