Uberlight newbie wants help
HeraHera Posts: 1,958
Why does this girl look like she's covered in ashes when using an uberlight upon her (no other light is used, and the default surface settings are used for for the girl and her top)
Post edited by Hera on
    It's at minimum quality. Select the uber light in your scene tab and choose the "4x" setting at the bottom of the list you loaded the light from.
    Ohai, Pierced Heart outfit. ;)
  • adamr001adamr001 Posts: 1,322
    I have a tutorial on UE2 here that might help : http://www.daz3d.com/forums/discussion/5320/
  • HeraHera Posts: 1,958
    Thanks heaps Adam!! Very helpful. Browsed trough it and will give it a more thorough read-trough later to get all those small tips and tricks.
    edited May 2013
    I had the same problem, but luckily I decided to try higher quality. In my humble opinion the highest one is worth waiting. See that "Far East Revisited" nocturnal scene which uses UberEnvironment and "Arlesienne - totally normal" which does not to see the difference.
    726 x 728 - 114K
    1024 x 1277 - 2M
    Post edited by cecilia.robinson on
  • Joe.CotterJoe.Cotter Posts: 3,362
    edited May 2013
    Uberlights came out a while ago when the hardware was not as strong on average. With complex scenes or old hardware, the presets lower then 4x are handy when doing test & setup renders to get the basic light set up. For final renders one wants to use 4x or higher (tweak some settings to beyond 4x.) Iirc, Adam's tutorial covers when and how one would do that. It is a great resource for Uberlights :)
    Post edited by Joe.Cotter on
  • revenger681revenger681 Posts: 156
    I never really used uber lights myself.... Always had them in my daz folders but when I tried them a few times I got results just like the one you posted, Lol.... but man with a little fiddling around with the sample settings it helps a LOT. What I did was dock the "properties" tab to the left bar (opposite from the content library) then clicked on the presets and watched which sliders moved around and learned what changes were taking place.
