Texture Errors Using G2 Figures...
If you look at the faces of the character on the far left (the elf in the white shirt) and the character on the far right (the woman in the black outfit), you can see these weird striaded lines on their faces. I have gotten this error before on other renders using G2 figures as well. Any idea what's causing it and how to fix it? Thanks!
Post edited by onimusha on
Btw using DAZ 4.10 on a Windoes 8.1 machine. Only had three spotlights going. I could figure out which texture character sets I used if that matters.
I believe it is the AoA SSS shader quirk. Make sure the two characters are using unique SSS ID numbers for their skin surfaces.
Thanks!
