Skin morph
Hey,
is it possible to do a skin morph?
If I would take for example a white skin and a black skin  from an african character, would it be possible to have a transsition from Skin A to B? Ideally with a slider.
  • It would probably be possible to do that with a custom shader in Shader Mixer, but I don't think anyone has. Another option is to use a Geometry Shell (Create>New Geoemtry Shell) with one set of maps on the base figure and one on the shell, then gradually raise the shell's opacity
  • Oso3DOso3D Posts: 15,115
    You could do it with my OMS1 shader using a map to layout which skin is used where, but not a slider.
  • Hurdy3DHurdy3D Posts: 1,109
    Hey thanks for yous answer.
    I tested sucessfully the geometry shell. This feature is great and does exactly what I want. But it seems to have it‘s problem with „addons“ to the body like the female golden place genitals.
    Therefor this feature is unusable for my purpose.
    I didn‘t find the time for checking the Shader Mixer (seems a little bit complicate).
    OMS1 shader sounds interesting, but I‘m not sure if this is what I search for my project.
    However, I switched for the moment to a much simpler solution. I just render the pictures twice (with both skins) and do the transition in photo shop.
    When I find time I will take a look at the shader mixers.
