Iray Hair help please
in The Commons
Is there a way to convert iray hair to 3delight?
I don't render in 3DL but maybe try applying a 3DL shader to the hair and see how that looks? :)
What are some good ones to get? @Divamakeup
I'm sorry, like I said I don't render 3DL so I don't know. :( Maybe someone else who renders in 3DL can help. I'm sorry I couldn't be more help.
I spoted this today in the freebie forum IrayTo3Delight conversion script i don't know how good it will be
I don't use 3Delight much either, just did some tests a while ago and it turned out Iray was much faster on my system. Since most DAZ hair are just transmapped surfaces I wouldn't expect too much trouble converting them. I also found this quick tip it may be a good start.
https://www.youtube.com/watch?v=6uriHey-VsA
https://www.daz3d.com/forums/discussion/139326/irayto3delight-conversion-script
If you can make universal Iray hair textures that work on almost any hair, which there are several examples of, the same should be possible with 3DL I believe.
