I need a hand! with a pointed finger
Box8068_31c338ee4bBox8068_31c338ee4b Posts: 292
No No not applause.
I do technical animations where I build all the models in Carrara.
In this case I could use a finger ( on a hand maybe) to push some buttons for a close up.
The hand included in the Carrara objects browser is Kinda cartoonish.
I haven't loaded the figures that come with Carrara 8 Pro because I found all the elements a bit confusing and I don't
normally need them. Anybody know where I could get a kinda realistic hand?
Thanks in advance!
8068
  • Box8068_31c338ee4bBox8068_31c338ee4b Posts: 292
    Holly
    Thank you again. They look good, and the cost is reasonable.
    I'm assuming I would purchase the OBJ files?
    Thanks
    8068
  • HeadwaxHeadwax Posts: 10,543
    hya, if you do decide to use michael or who ever, assuming he comes with carrara, just pose the hand as you want, then export his obj with morphs and skinng applied, then bring it back in to the modeeling room, use select by material, choose hands then fingernails, then invert your selectin and delete, you will just have the hands, then select the one you don't want and delete itthen in t he assembly room reset the obj centre
    Might just be simpler to load a figure and figure it out- So to speak. ;-) If it's just the hand there's no need to mess with clothes or hair or any of the other stuff.
    heh, now why I didn't i think of that !
