problems with MEC4D HDRI Abandoned Industrial-Megapack
I bought MEC4D HDRI Abandoned Industrial-Megapack in September and I still can't get it working.
HDRI file doesn't load, only cameras appear in the scene.
I already tried uninstalling, reinstalling, downloading thru browser, thru manager and still the same.
GARDENS vol 2 and CASTLE works fine. :(
Do you get an error message?
I think there is a bug. If there is already a camera in the scene, the load process aborts before it can load the HDR files. If I start with an empty scene, it works.
i have the same problem. I can just load 1 HDRI. When i try to load the others, it doesn't work.
I figured it out. After opening daz, before doing anything else. I load the HDRI and I go to my render settings and tweak them how I would like them and I save the scene as a Render Preset and put that in my render preset folder. Now if I ever want to use that HDRI, I can click on it and it will load the HDRI. The camera's are not actually necessary for the HDRI to work. You can add cameras normally from then on.
