Very slow viewport performance
ISIKOLISIKOL Posts: 386
edited February 2018 in Daz Studio Discussion
hello everybody....im experience lately a very slow performance on the viewport...when using iray.... its extremeley slow even thought i have a powerful computer. I have 2 gpus ..one 970 and one 1080 ti! With an i7 and 32 gigs of ram....
i have tried all possible combinations in the render engine settings.... 2 gpus wit optix performace is currently enabled...i also,changed the settings from better to best in the preferences / viewport and still nothing...
is there anything else you propose me to do in order to see any change.? Im on windows 10 pro fall edition....
Even with one simple figure it takes a lot of time to preview and when im just hovering around the figure turns white and then starts loading the textures from scratch....
please help me on this....thanks...
Post edited by ISIKOL on
  • algovincianalgovincian Posts: 2,670
    This has happened to me for figures that have a high sub-d - might be worth checking. Robbus Madgloom comes to mind (loads at sub-d 4).
    - Greg
  • ISIKOLISIKOL Posts: 386
    Hello my friend...even with sub d at 1 i have the same problems....
    You may try reading through this thread (you're not the only one):
    https://www.daz3d.com/forums/discussion/168856/daz-imposibly-slow-laggy-in-viewport-even-in-blank-scene
    Hope you can figure out what the issue is. BTW, I knew your name looked familiar . . . love your artwork!
    - Greg
  • FishtalesFishtales Posts: 6,216
    Go to Menu Windows/Panes/Draw Settings
    Make sure Draw Style is set for Iray.
    Under Drawing change Response Threshold and Manipulation Resolution until you are happy with the speed. I have them set at 10 and ¼ respectively.
    I hope that helps.
  • nonesuch00nonesuch00 Posts: 18,765
    I'm not using iRay preview for the viewport but openGL texture shaded for the viewport and I had similar problems with extreme DAZ Studio slowness until I make every Windows/Panes/Draw Settings the least intensive setting availble and saved. Now the extreme lagginess is gone.
  • PadonePadone Posts: 4,030
    There could be many reasons for the viewport to be slow. I would advise you to start with a simple sphere and add up until you find what's the limit. If even a simple sphere is sluggish then it can only be drivers and/or a Windows update. Of course keeping a single viewport may help as well. Below some suggestions that I believe most useful.
    - Always use a separate gpu for the viewport so to have the main gpu free for Iray. This is the only way for complex scenes to avoid slowing down the response to user interaction. In modern systems, having a good integrated gpu in the processor, it is enough to wire the monitor to the mobo.
    - If the materials in the scene are complex then it helps a lot to use the interactive mode instead of the photoreal. Because the interctive mode itself simplifies materials to achieve a better speed. Of course you will also have a worse approximation, that may not be acceptable to you depending on your needs. So always do a comparison before switching to interactive.
    - In render settings set max samples to a reasonable low value to avoid unnecessary overloading of the gpu. In most cases 128 or below are good enought to have an acceptable representation in the viewport. Also it helps to set a low value in max ray bounces (for interactive) or max path lenght (for photoreal). In this case also you're manipulating the viewport quality to get speed so be aware of it. If you see strange things happening such as eyes turning black it may be necessary to allow for more bounces.
    Post edited by Padone on
  • dijituldijitul Posts: 146
    I know this thread is old, but once again I was looking for a solution to this problem and didn't find the answer on the forum.  However, I did find one cause of slow viewport response and that was related to the Aux Viewport.  If the Aux Viewport is set to iRay, then it'll impact the response time of the default Viewport even when you're not looking at the Aux Viewport.  So, click the tab for Aux Viewport and make sure it's set to the fastest preview mode, then close the tabe if you're not using it.  Hope this helps somebody...
  • Hex was always great and now its un-usable .. Its too laggy to do anything . Was it some Windows update that messed it up . ? .. Hope someone has a solution or Ill just give up and go to Blender for everthing now ..
  • Hey Guys,
    I think I found the answer by mistake. In my case, I forogt the PC on for a day. After 6 hours all was working like butter. Super smooth and super fast. You would not believe it.
    Maybe, the database is doing some indexing in the background.
    Just let DAZ3D open for a long time and all will be awesome! I hope you'll have some great renders...
  • AstrozAstroz Posts: 18
    my computer oist strong but slowing  down for no reason in viewport
    can not even navigate and zoom in it.
    I use 2% GPU and CPU, so why?
    I tried everything
