Adding to Cart…
Returned to this and thought if it has webs it needs a spider.
2018-01-31 02:05:07.592 Total Rendering Time: 5 hours 56 minutes 9.9 seconds
2018-01-31 13:26:25.071 Total Rendering Time: 5 hours 33 minutes 52.65 seconds
I had a scene made up using just The Library, all the surfaces are Iray probably using the addon, so I added some billboards and re-rendered it. The only change between the two renders was the Crush Black setting.
2018-02-01 12:33:29.713 Total Rendering Time: 18 hours 32 minutes 16.25 seconds
Crush Blacks 0.0002
2018-02-02 02:49:21.667 Total Rendering Time: 13 hours 58 minutes 57.35 seconds
Crush Blacks 0.9998
Too much Babylon 5 re-runs :)
2018-02-04 15:58:40.693 Total Rendering Time: 4 hours 22 minutes 11.79 seconds
You'll leave when I say you can go!
2018-02-06 03:26:47.271 Total Rendering Time: 5 hours 14 minutes 20.82 seconds
2018-02-06 13:07:08.196 Total Rendering Time: 5 hours 10 minutes 7.78 seconds
I really like this series. Very cinematic. Beautiful terrain and convincing light/long shadows.
@Rakuda Thank you.
Bear Cubs Playtime
2018-02-10 19:58:58.910 Total Rendering Time: 4 hours 18 minutes 36.58 seconds
I'm clearly behind. Really like the spider renders and love the sci fi render close up of the guy kneeling.
@IceDragonArt
Thank you for dropping in. I was beginning to think I was on a "Universal Ignore List"
Keep watching Babylon 5 if the result is more sci fi renders ;) Really adore the bear cubs at play!
@Worlds_Edge
Thank you.
Love the bears! playful and nice lighting!
@Rakuda
Thank you. It is Sun and Sky and set for early morning.
This is my personal favorite of your to date.
@ssarts
Thank you. That one did turn out well.
Another space one with the Reliant and the Defiant. The background is a 10k HDRI of the Crab Nebula.
2018-02-15 16:40:33.711 Total Rendering Time: 37 minutes 0.31 seconds
Click on image for full size.
2018-02-15 18:11:02.992 Total Rendering Time: 44 minutes 46.28 seconds
2018-02-16 00:33:41.388 Total Rendering Time: 1 hours 53 minutes 8.82 seconds
The Klingons are coming.
Did this one first and then realised it was upside down.
2018-02-16 20:14:39.480 Total Rendering Time: 3 minutes 16.98 seconds
2018-02-16 20:42:48.515 Total Rendering Time: 5 minutes 53.94 seconds
Decided to merge the last two scenes.
2018-02-17 13:29:44.518 Total Rendering Time: 7 minutes 36.70 seconds
Dragon Bath Time
2018-02-28 13:52:44.691 Total Rendering Time: 16 hours 26 minutes 22.14 seconds
2018-02-28 16:07:39.814 Total Rendering Time: 1 hours 45 minutes 31.89 seconds
Really like the space renders, and the dragon bath is adorable!
@IceDragonArt
Thank you. Did you notice the difference in render time between the two bath renders? The difference is marked but I don't think I did that much to make such a big difference.
I did and on second look, the biggest difference I see is in the water pouring down. My guess is that's what did it, because anything that uses reflections, refractions etc will add a huge amount to the render time.
@IceDragonArt
Nope, all I did was turn off caustic sampler and moved the Dome 180 but I wouldn't have thought that would make that big a difference.
One wouldn't think. But then again, there's no telling with this program lol.Would be interesting to see if you had just one water prop in a scene and did a render with caustic sampler on and one with it off.
Just some fun with various characters.
The Crystal Cave
2018-03-13 05:48:44.021 Total Rendering Time: 15 hours 43 minutes 24.53 seconds
This was just a light test using a three sided box and floor, no ceiling, two point lights and the Dome set to Dome and Scene at 0.10 intensity, no map.
2018-02-09 15:06:48.611 Total Rendering Time: 1 hours 33 minutes 39.55 seconds
I've neglected Bryce so here is one from last year.
Beneath the Ship.
Love that bat hanging down in the cave. And it kind of looks like one dragon is trespassing and the other is not terribly happy about it!
Great reflections on the motorcycle. And I had no idea you could do a half above and half below water scene in bryce.
@IceDragonArt
It has been that long since I did that I can't remember how I did it :)
