Searched all over! Can someone help me find a hair like this one?
posecast
I'm hoping someone on here can help me to find a hair that matches this one as closely as possible. Any ideas?
Thanks for looking!
Post edited by posecast on
Try Moira Hair over at renderosity
That's much closer than what i had found so far!
The closest that can be found here that I know of are.. While not exact they are close..
https://www.daz3d.com/harlow-hair-2
https://www.daz3d.com/marisandra-hair-2
https://www.daz3d.com/portia-hair
Edit:
I removed the image.
While I don't intend to sell a product using the image, I have removed it because of the tricky potential legal ramifications involved in using something labeled as Creative Commons. Thanks to CyperFOX for the warning!
Greetings,
@posecast - Just...not to be nit-picky, but if you're going to use the original (which you entirely have the right to, if you look at the license on the flickr page) you need to give attribution. It's from this flickr page as far as I could tell.
It also means that anything you release that re-uses the original is also under the (by-sa) share-alike license. I'm not a lawyer, though, so I don't know what it means if you use facegen or something like it with that picture. It seems like it might be a derivative/remixed product, so...just be careful. Please take this as it's meant, as a helpful pointer, not a criticism at all.
-- Morgan
Thanks CypherFOX...it's not for a product, it is to demonstrate the process to someone. I will remove the image. Thanks for the reminder!
This may work <https://www.renderosity.com/mod/bcs/70s-hair-for-g2f/113011/> at Renderosity.
