Ready !! - mcjA3CropTop -- Summer Crop-top for Aiko3
it’s ready !!!! yay yay !
A very tight fit crop-top for Aik0 3, includes 17 body morphs
Stylized
Realistic
FullFigure
Muscular
Young
Voluptuous
BreastSize1
BreastSize2
BreastSize3
BreastSize4
BrstNatural
BrstDiameter
BrstCleavage
BreastLift
ChstWidth
WaistNarrow
LwrBdyWidth
https://sites.google.com/site/mcasualsdazscripts3/mcjacroptop
Post edited by mCasual on
Oh, beachwear! And just in time for summer renders, too!
(looks at subject line)
"Aiko2"? Is there an Aiko that I missed somewhere? She looks a lot like Aiko3... :-)
On the numbers keyboard "5" is right above "2". I guess that´s the reason for this mistake. And the outfit looks very nice!
I believe that it is version '2' of the crop top. It is for Aiko 3.
progress report, i made the hems that, i believe improve the look a lot
3rd image shows the hems were inflated using a morph created with the help of mcjElevate
( https://sites.google.com/site/mcasualsdazscripts/mcjelevate-reva )
4th image shows the whole crop-top being inflated using a morph created with the help of mcjElevate
thinking i should make the "belt" of the crop-top fit tighter, maybe the shoulder straps too need to be improved
and, maybe i'll complete the bikini bottom and post it too !
Aiko 3 was internally referred as Aiko 2 during her development way back when.
I'm interested. :D
same top and bottom but tightened onto her body
notably, the shoulder straps now rest on the shoulders and the upper part of the breasts
the sort of chest belt also is perfectly fit
though come to thing of it, how would she put it on?
also note the hems are not "rebuilt" yet
then since it's an old-school clothing item, i have to generate and tweak all the morphs ( up to 50 )
It looks really neat on her now, much better.
thanks!, looks like i could tighten them a bit more but i'd have to battle poke-through
anyway i may add a "tighten" morph
at one point one would need to convert Aiko to subDs
shown here the 11 hems were created
It looks really well now I think, it is only at some angles that you would be able to 'see in' to the perforations on the side. I think it is acceptable enough as it is. It is a great set for anyone who wants to use A5, and probaly Genesis as well.
i'll rig a morph-less Aiko3 aiko3 version and see how it fits for Gen
kuxrender render - the hems are finalized ... for the bikini bottom
Very carefully... :)
It looks like it wouldn't be any more difficult to put on than a sleeveless t-shirt would; she'd just have to be careful it's arranged properly before stepping out of the change-room.
somehow i had lost the tightened version,
but it's back ! now i have to regenerate the little 11 hems
in the 2nd image the sand is very very compacted and allows walking in high heels
and the shadow-thieves stole the shadows
That looks a lovely little outfit Casual.
I agree, it's really good. It is the very definition of 'Smart Casual', and the top could be used for so many things.
EDIT:
The pun was unintententional, but it is very apt :-)
the blank bikini bottom test dance
that's the bikini bottom, rigged as a figure, no morphs, so today probably i'll be able to convert it to a Genesis asset/figure
there's just one brief poke-through event when the thighs and buttock side-side rotation is extreme
well actually there's an other one *mumble*
( 5th Element stewardess top wont be distributed, lets say it's for Amy only )
i'm not very knowledgeable concerning fitting clothes in Daz Studio 4.5
that's the result of fitting the A3 bikini bottom to Genesis ... not really useful so maybe i'll concentrate of finishing the top and bottom for Aiko3
Looks great so far. I'm always interested in new Aiko3 stuffs.
It looks great! Does it require many JCM's? The test dance animation is amazing too. "it's for Amy only"? For me? :red:
i'll probably post the bikini/bottom without morphs, without JCMs, ... the same as used in the animated gifs dance
since almost everyone has DS4.5 it's possible to transfer the morphs from Aiko
later on i'll probably re-publish the bikini bottom with the (corrected) morphs
and i'll post the dance cycle animation ( it's a very mathematical dance using sines and cosines )
my Aiko based actress was named Amy by Posette in the video https://www.youtube.com/watch?v=L-S3NWXT7vI
but since you're an Amy too, the dance must be made just-for-you ... too :)
progress report
worked a bit on the leg-sit-or--walk morph
for small leg-joints rotations, like during a walk it's not needed though
... ooops this is meant for the bodycon dress thread !
resuming work on the crop-top and later on the bikini bottom
crop top ( with racerback ) news
a cone follows a row of vertices of the crop-top mesh
this will be used to re-generate the crop-top for each of the 20-something morphs that will be included
when you'll apply a morph like "Breastsize4" or "Breastsize1" the crop top will keep its nice tight "tent" behavior
instead of looking glued on to the skin ... which is what i'd obtain using morphs provided by Daz Studio's 3's morph follower
( the results were not that bad though as you could see with the mcjA3Le03i )
check out the Yoda-worthy morph, regularizing the crop-top's mesh :)
once the "fibers" of the crop top have been normalized and straightened
"convex hull" processing was used to put them under tension
so we get a sort of tent effect or bridges
a minimum of 1.5mm of distance is maintained
( 1 mm gave some poke-through )
Very neat and tidy.
see see the difference?
science ladies and gentlemen science
( breastsize3 morph created using scripts )
image 2 -- the breastsize4 morph didn't work as well, you could say my tailor-robot didnt crouch enough to work correctly on the under...
image3 -- breastsize2 no problem
image 4 -- breastsize 1
image 5 -- Cleavage -- i was expecting that one to be problematic, it's not!
i still have to show tell my tailor-robot to adjust the waist band and the back
excel graph showing an issue ( don't worry it will be resolved ) wherein the convex-hull treatment ( tent effect ) isn't working properly
note that it works fine most of the times but something's happening on the bridge over the Clavicle Lake
once that's resolved i will be able to quickly complete the morphs
( crossing fingers on the collarBend morph )
great news, a hurdle on the road to the crop top has been overcome
the convex-hull ( tent / bridge effect ) did not work correctly because :
i developed it initially for the bodycon dress
the dress is a stack of tightened horizontal loops
for the crop-top's bra we have a series of vertical ribbons, a bit like bows
figure 1 : Here you see Aiko3 with the "Stylized" morph at 100%
figure 2 : the back strap will probably just hover over Aiko's back
figure 3 - Blender render details - the nice environment background comes from http://www.hdrlabs.com/sibl/archive.html
a large cube of light gives us soft highlights on the skin and clothes
