Carrara Benchmark - Scene and results
3drendero3drendero Posts: 2,037
edited February 2018 in Carrara Discussion
Just found an old Carrara benchmark scene by Kixum, posted in 2010 in the Rendo forums, but it seems to older since Carrara 5 is mentioned and a web site with old scores list very old PCs:
http://renderfred.free.fr/c5pro_bench.html
For example Pentium4 at 20 minutes and Core 2 Duo at 10 minutes
Benchmark file: https://www.renderosity.com/mod/freestuff/carrara-benchmark/60396
To keep it similar to the web site, I changed the resolution from 1280x1024 to 800x600 (the benchmark file on the renderfred site is 800x600):
Intel-2700@3900MHz (4C/8T) on Win10 64Bit in 800x600:
Carrara 8.5 Pro: 1 minute 22 sec
Carrara 8.1 Pro: 1 minute 20 sec
Intel-2700@3900MHz (4C/8T) on Win10 64Bit in 1280x1024:
Carrara 8.5 Pro: 7 minute 21 sec (Default tile size 128)
Carrara 8.5 Pro: 7 minute 04 sec (Modified tile size 64)
Carrara 8.1 Pro: Not tested yet
Probably need to run it a few times to average out the score and shut down all other apps, but I will leave that for another time, when testing overclocking too.
Some runs were up to 1:30.
What is your score???
Post edited by 3drendero on
«1
    i5 @3.2GHz (2C/4T) MacOS High Sierra (10.13.2) Carrara 8.5 Pro:
    800 x 600: 2 minutes 45 sec
    1280 x 1024: 13 minutes 18 sec
    Post edited by TangoAlpha on
  • UnifiedBrainUnifiedBrain Posts: 3,588
    edited January 2018
    i5-3450 @3.10 GHz.  (4C/4T)  Windows 7 Pro.  Carrara 8.5 Pro.
    9 minutes and 20 seconds at 1200 x 1024 resolution (default).
    2 minutes and 2 seconds at 800 x 600 resolution (as suggested).
    Post edited by UnifiedBrain on
  • chickenmanchickenman Posts: 1,202
    edited January 2018
    i7 4790K @4.3 Ghz (8C/16T) Windows 10 Pro 32 Gb RAM, liquid cooled, dual R7 250 2Gb video cards,
    1280x1024
    Default carrara render engine default bucket size 5.14 minutes.
    Default carrara render engine 16 bit bucket size 6.33 minutes.
    800X600
    Default carrara render engine default bucket size 1 min 5 seconds .
    Default carrara render engine 64 bit bucket size 1 minute.
    Default carrara render engine 32 bit bucket size 1 minute 4 seconds.
    Default carrara render engine 16 bit bucket size 1 Min 14 Seconds.
    Luxcore does not recognize the blue so it is a bust.
    Post edited by chickenman on
    AMD Ryzen 1700X 8C/16T CPU OC
    ASUS Prime B350-Plus motherboard
    Cooler Master Hyper 212 Turbo Cooler
    32G DDR4 Kingston Ram
    256G SSD M.2 Intel 6 Gen PCI Express + Seagate 2TB HDD
    ASUS 8G GeForce GTX 1070 PCI Express
    Cooler Master MasterBox 5 + 650W Power Fractal Design
    22 Speed DVD RW ASUS
    Built in Gigabit Lan USB 3.0 SATA 3.0
    Windows 10 Home 64
    sorry don't know what's relevant as far as hardware
    8.1 default bucket size 1 min 8 secs (same result with two renders)
    8.5 tile  size 128 -  1 min
    8.5 tile size 16  - 43 seconds
    all renders 800 by 600
  • Bunyip02Bunyip02 Posts: 9,345
    edited January 2018
    Intel SKYLAKE Core i7-6700K CPU, 4.0GHz Overclocked to 4.2-4.4Ghz Quad Core 8 Threads, 8M Cache
    Gigabyte Z170X-Gaming 3 DDR4 VGA 7xUSB3 USB-AC 7.1 HD Killer LAN motherboard
    Corsair H80 Water Cooling CPU Cooler
    32 Gigabytes 2133Mhz DDR4 GSkill / Crucial
    512 Gig SAMSUNG 850 PRO SERIES SSD SATA 3 R/W(Max) 550MB/s/520MB/s & 2 x 4 Terrabyte Seagate SATA3
    nVidia GEFORCE GTX 1060 6GB DDR5 DVI/HDMI/DP
    Thermaltake/Cougar/Coolermaster 80 Plus 750W Heavy Duty
    LG/SAMSUNG DVD/CD Burner 24 Speed
    WINDOWS 10 PRO 64 bit
    Carrara 8.5 Pro
    1 min 5 seconds
    Post edited by Bunyip02 on
  • SileneUKSileneUK Posts: 1,980
    edited January 2018
    1 min 7 secs with default settings with Carrara 8.5 Pro
    PC SPECIALIST:  Case   COOLERMASTER CM690 III ADVANCED CASE (GREEN)
    Processor:  (CPU) Intel® Core™i7 Quad Core Processor i7‐4790k (4.0GHz) 8MB Cache
    Motherboard  ASUS® Z97 WS ‐ ATX, USB 3.0, SATA 6 GB/s
    Memory (RAM)  32GB HyperX FURY DUAL‐DDR3 1600MHz (4 x 8GB)
    Graphics Card  PNY QUADRO K2200 ‐ 4GB GDDR5, 640 CUDA Cores ‐ 2 x DP, 1 x DVI
    1st Hard Disk  240GB HyperX SAVAGE SSD, SATA 6 Gb/s (upto 560MB/sR | 530MB/sW)
    2nd Hard Disk  2TB 3.5" SATA‐III 6GB/s HDD 7200RPM 64MB CACHE
    Power Supply  CORSAIR 650W VS SERIES™ VS‐650 POWER SUPPLY
    Processor Cooling Corsair H100i GTX Hydro Series High Performance CPU Cooler
    Thermal Paste  STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
    Operating System Genuine Windows 7 Professional 64 Bit w/SP1 ‐ inc DVD & Licence
    Post edited by SileneUK on
    Sounds like I need a faster computer, lol
  • pimpypimpy Posts: 274
    Carrara 8.1. pro
    1280x1024 – 5 min 55" (128 tile size)
    1280x1024 – 5 min 42" ( 64 tile size)
    800x600 - 1 min 07" (128 tile size)
    800x600 - 1 min 05" ( 64 tile size)
    PC : intel core i7 4790K -16GB ram – Windows 8.1 pro
  • 3drendero3drendero Posts: 2,037
    edited January 2018
    Yeah, neither Luxus nor LuxCore can translate the mixed shader, but the lighting is probably also wrong.
    They both need a new scene with new lighting to make a comparable benchmark scene.
    Anyone with Octane that wants to try?
    Yeah, I recommend a 16-core (32 thread) AMD 1950x threadripper.
    Probably the same price as a quad core Mac.
    Octane render demo vers. 2.17.0068
    3000 samples 1 min 45"  (1000x600px)
    Geforce GTX 960
    Or Just get a Z820 or somthing like that it should just scream through this test. Nice Dual Xeons they may be slower but designed to do the math.
    No price is worth the penalty of Windows! cheeky
    edited January 2018
    BUT Mac's support windows
    Post edited by Chohole on
    You been into the pre-6 Nations booze already? devil Silene
    There are some Hackintosh builds with the Threadripper 1950x, you get 16 cores at half the price of a Mac Pro with 8 cores.
    Or 2x16 core rigs for the same price...
    Hmmmm. Anyone got a spare billionaire lying around?
    £94,000,000  Euromillions Friday's Draw!!  wink Silene
    Geforce GTX 960
    How does the result look like?
    Similar to a Carrara native render?
    Check your bitcoin wallet or sell your rig and buy a used workstation, like posted by others here.
    I think it was HP z620, check ebay.
  • 6 mins 13 secs
    I have the suckiest PC so far
    ( is why I normally use OR4C as my 980ti is much better than my CPU with less upgrade expense including the plugin and Octane cost!)
    CPU Intel Core i7 4790
    Cores 4
    Threads 8
    Name Intel Core i7 4790
    Code Name Haswell
    Package Socket 1150 LGA
    Technology 22nm
    Specification Intel Core i7-4790 CPU @ 3.60GHz
    16GB RAM
    Motherboard
    Manufacturer MSI
    Model Z87-G45 GAMING (MS-7821) (SOCKET 0)
  • VyusurVyusur Posts: 2,235
    8 min 55 sec
    Intel Core i5 8 GB RAM
    th3Digit said:
    6 mins 13 secs
    Cores 4
    Threads 8
    Code Name Haswell
    Technology 22nm
    16GB RAM
    Motherboard
    Manufacturer MSI
    Hello Wendy
    I would have thought that your computer would have been faster than that, and a bit slower than the i7-4790K, seems like quite a difference.
    http://cpu.userbenchmark.com/Compare/Intel-Core-i7-4790K-vs-Intel-Core-i7-4790/2384vs2293
    http://cpu.userbenchmark.com/Compare/Intel-Core-i7-6700K-vs-Intel-Core-i7-4790K/3502vs2384
  • DiomedeDiomede Posts: 15,466
    I think there is a bug that makes the render take longer if you wait.  Seems like the times are getting slower and slower.
    12 minutes, 59 seconds
    Intel i7, 4 cores, 8 threads, 8 GB Ram
    EDIT:  The above was for the default size of 1280 x 1024.  Lower time for 800x600
    For 800x600, 5 minutes, 51 seconds
    Post edited by Diomede on
    Note that the fast times are 800 X 600 and I would guess the slower times are 1280 X 1024. THe size difference does make a difference.
    The speed of your RAM will also make a difference, is the CPU Over clocked? There are many factors that play into the speed of the rendering.
    8 min 36 sec on my mac
    i7, 8 GB RAM
  • ProPoseProPose Posts: 550
    Carrara 8.1. pro
    1280x1024 – 7 min 21" (128 tile size)
    1280x1024 – 7 min 09" ( 64 tile size)
    800x600 - 1 min 29" (128 tile size)
    800x600 - 1 min 23" ( 64 tile size)
    PC : intel core i7 3820 -32GB ram – Windows 10 pro
    Carrara 8.5. pro
    1280x1024 – 7 min 08" ( 64 tile size)
    800x600 - 1 min 24" ( 64 tile size)
    Carrara 8.1. pro
    1280x1024 – 5 min 29" (128 tile size)
    1280x1024 – 5 min 24" ( 64 tile size)
    800x600 - 1 min 06" (128 tile size)
    800x600 - 1 min 02" ( 64 tile size)
    PC : intel core i7 4790K -32GB ram – Windows 10 Home
    Carrara 8.5. pro
    1280x1024 – 5 min 33" (128 tile size)
    1280x1024 – 5 min 28" ( 64 tile size)
    800x600 - 1 min 07" ( 64 tile size)
  • To all contributers, if you don't post the render size (either the default 1280x1024 or the suggested 800x600), the time you post doesn't mean much.
    ??  I just rendered again at 800x600, and it took almost exactly the same amount of time it took before, about 2 min on an i5.
    3drendero suggested 800x600 - "To keep it similar to the web site, I changed the resolution from 1280x1024 to 800x600 (the benchmark file on the renderfred site is 800x600)"
    My original time of 1 min 5 seconds is for 800x600
    Did another render for 1280x1024 and got a time of 4 mins 30 seconds
    OT: I've noticed with other renders that if I change a texture in a scne and go and render it takes longer the first time I render it
    the next time I render the scene it is quicker (if I dont change any textures or add anything with textures) - I assume it's because of texture spooling?
    anyone else notice this ? I see Fenric notes :  https://www.daz3d.com/forums/discussion/comment/437527/#Comment_437527
     You need to turn off texture spooling on 64-bit systems if you are using any of the Global Illumination options, or Carrara spends too much time fiddling with spooling textures instead of rendering.
