single body parts with skin, single skeleton bones and single organs
cosmo71
hello,
for horror or other renders it would be great to have:
-single body parts of a complete body with skin and morphs for v4/m4/genesis
-single skeleton bones of a complete skeleton
-single organs
it should be possible to change the skin texture just by click:
example:
you have a character, for example m4 with a skin texture
and you have a single arm.
it should be possible to set the shape settings of the m4 arm to the single arm and also the skin texture for limbs
understandable?
the single bodyparts should be closed at the ends and the closed ends should have extra textures
Post edited by cosmo71 on
Poserotica has a bunch of creepy stuff like that. (or at least they used to).
Also check out V4 Mannequin
Mannequin
Edit link
Here are some body parts I have used myself...
http://www.renderosity.com/mod/bcs/flesh-and-bones-1-by-3-d-c/89499
I have a few others, but I can't remember them offhand.
Best of luck!
:coolsmile:
ah thanks, the flesh and bone stuff I already have:)
Poserotica? So far I know does the site not exist until now, it is upcomming
HellboySoto created a decapitation set for V4. As the original link is on an adult forum, I'll post the link to the download:
http://www.4shared.com/file/93127555/58c0f99e/SOTO_Decapitation_for_V42.html
Here's what it looks like: http://jcsoto.jalbum.net/XXX/SOTO_Decapitation.jpg
(No nudity on the image)
It does not work properly on Genesis as the neck areas are different. Genesis retains an area in the back of the neck when you try to use this with it.
I believe he's referring to MalePoserotica, which is very much there.
this render is really creepy, is that just for the head or also for limbs or is there something like that for each body part for m4 and v4?
As is Renderotica.
Soto's is only for the head. I'm not sure if he has ones for the limbs.
