single body parts with skin, single skeleton bones and single organs
cosmo71cosmo71 Posts: 3,609
edited May 2012 in Product Suggestions
hello,
for horror or other renders it would be great to have:
-single body parts of a complete body with skin and morphs for v4/m4/genesis
-single skeleton bones of a complete skeleton
-single organs
it should be possible to change the skin texture just by click:
example:
you have a character, for example m4 with a skin texture
and you have a single arm.
it should be possible to set the shape settings of the m4 arm to the single arm and also the skin texture for limbs
understandable?
the single bodyparts should be closed at the ends and the closed ends should have extra textures
Post edited by cosmo71 on
  • MarcCCTxMarcCCTx Posts: 947
    edited May 2012
    Poserotica has a bunch of creepy stuff like that. (or at least they used to).
    Also check out V4 Mannequin
    Mannequin
    Edit link
    Post edited by MarcCCTx on
  • tsaristtsarist Posts: 1,642
    Here are some body parts I have used myself...
    http://www.renderosity.com/mod/bcs/flesh-and-bones-1-by-3-d-c/89499
    I have a few others, but I can't remember them offhand.
    Best of luck!
    :coolsmile:
  • cosmo71cosmo71 Posts: 3,609
    ah thanks, the flesh and bone stuff I already have:)
    Mannequin
    Edit link
    Poserotica? So far I know does the site not exist until now, it is upcomming
    edited May 2012
    HellboySoto created a decapitation set for V4. As the original link is on an adult forum, I'll post the link to the download:
    http://www.4shared.com/file/93127555/58c0f99e/SOTO_Decapitation_for_V42.html
    Here's what it looks like: http://jcsoto.jalbum.net/XXX/SOTO_Decapitation.jpg
    (No nudity on the image)
    It does not work properly on Genesis as the neck areas are different. Genesis retains an area in the back of the neck when you try to use this with it.
    Mannequin
    Edit link
    I believe he's referring to MalePoserotica, which is very much there.
    Post edited by Lissa_xyz on
    Mannequin
    Edit link
    this render is really creepy, is that just for the head or also for limbs or is there something like that for each body part for m4 and v4?
  • AscaniaAscania Posts: 1,856
    As is Renderotica.
    Mannequin
    Edit link
    Soto's is only for the head. I'm not sure if he has ones for the limbs.
