models not showing in viewport
I have put this to daz no help there,gave me one answer to reset my workspace and called it closed.windows and Daz updated the same two day pirode and has been this way ever since.the modele is loaded in premeters and will render but I cant see or move it in any way.anyone have any ideas,All my drivers seam to be up to date nivida graphic;s.work fine before the updates
thank you for any help
here is a snap shot
The tab says Viewport but it is actually shopwing the top of the Render Library pane. Have you tried using Window>Workspace>Select Layout? What video card are you using, and are the drivers current?
yes I have redone the work space,endup downloading on my LP works there this happend after windows updated again.When I check my card in daz everthuing is good to go .must be the PC its old .I just hate to have to wipe out and redownload 2500 + models lolAnd I did render it to show the models is there jus not in the viewport and cant move it.nivida gforce
