Never Let Ledhead Name a Complaint Thread Complaint Thread
1313234363750
  • M F MM F M Posts: 1,388
    edited May 2013
    Kyoto Kid said:
    KK:
    Log file is in C:\Users\You\AppData\Roaming\DAZ 3D\Studio 4, along with saved layouts and all the other stuff that was in Documents and settings...Application Data under XP. There's also a Studio 3 folder for DS3.
    Your content, by default, goes in \DAZ 3D\Studio\My Library in your Documents folder (C:\Users\You\Documents) for DS4 and to \DAZ 3D\Studio 3\Content for DS3.
    Your applications will be in C:\Program Files (64 bit) or C:\Programme Files (x86) (32 bit).
    Most of the folders you list don't exist on Vista and later, applications never should have had hard-coded paths to them (after all, several included the suer name and so varied from system to system) but used and use environment variables to obtain the correct location for the system.
    ...so one of my questions is, why is there also a locked folder icon named "Application Data" (where the Daz logfiles in XP were routed), and again, as I am the admin on my own system, why is it (and other folders) locked out at all (giving a "Access Denied" error when clicked on)? In my view, this is just bad coding, it's not like I'm going to sabotage my own system I spent all these months and hard earned money to design and build. There has to be a switch or command somewhere to "unlock" these. ...
    Because they are (most likely) Junction Points KK -- there is NO command to "unlock" them. (sidenote: VMS had a similar 'SET FILE/ENTER=...' if that's something you had experience on). I'm not quite sure how you've managed to achieve the (logical) filesystem you have, but there is definitely Something Weird(tm) going on.
    Please try that "DIR /aL /s /p" command I listed above, and see what it shows you about the directories under C:\ProgramData\. If it comes up with a bunch of errors about not being able to read directories in there, then yes you HAVE got a totally weird system (access-wise), and the quickest way to return to sanity (totally imho - Ps1 may correct me on this) would be to reformat your C: and reinstall from scratch.
    Post edited by M F M on
  • TJohnTJohn Posts: 11,379
    And the main autofit problems I've experienced have been with Gen 4 and Gen 3 footwear.
  • WoolyloachWoolyloach Posts: 0
    I still use Aiko 3 a lot, but she's showing her age. :-S I also have some outfits that ONLY fit A3 and V3 with no Gen4 equivalents.
    If I could simplify the workflow to: load Genesis, load proper generation morph, load morph and clothes, render.. it'd be nice. Anything that would shrink my runtime a bit would help too, my DAZPeople runtime is an unholy jumble of Gen3/Gen4 figures and morphs! :ahhh:
    I still need a program that will figure out what clothes go with what figures and generate a spreadsheet. :-S There's a nice C# coding project for me.. :-S
  • JaderailJaderail Posts: 0
    Note to KK, who EVER installed your Win7 OS to the new PC is to blame for your issues. The install was not DONE properly and thus has locked the Admin as a standard user account.
    All Programs should and do install on a proper Win7 to one of two locations unless the user points the installer to a different folder
    Program Files, which is the Default 64 bit location or
    Program Files (x86), which is the Default 32 bit location.
    My Documents has been the catch all folder for most programs for a long time. SketchUp defaulted to it, Wings 3D defaulted to it and many others I use as well. Just because you think it is not supposed to be that way does not mean it's not supposed to be that way. My Documents is the Documented MS proper folder to store any user content for a MS compliant program.
    If I was in your position I would have the Win7 OS installed by a PC repair shop and EXPLAIN the reason WHY.
  • RakceyenRakceyen Posts: 27
    Umm, whats going on here?
    I have the DAZ 4.6 beta
    Im using the dynamic clothing plugin that came with daz
    All default settings on the sheet, no wind or moved dials.
    It is set to Collide with All
    And I started the drape way above the horns. The sheet just passed through the head and seemed to catch onto the eyes and the shoulders.
    I tried something similar with a trex, and only half of the trex's face got covered. The left side reacted with the sheet, while the sheet passed through the right side.
    Genesis works fine, although when it touches the bed it becomes really crinkled. Looks like the surface of a sponge when it hits the bed.
    1920 x 1080 - 1M
  • ps1borgps1borg Posts: 12,776
    Morning. Chill South wind and cold under a pale blue sky, no sign of rain today :)
    Subdivide any mesh that does not have a high enough mesh count for Dynamic collision's. The Dynamic controller can not calculate against low mesh items.
    edited May 2013
    SubD. Does the process work for the release version of 4.5?
    Post edited by ps1borg on
    Omgggggggggggggggggggggggggggggggggggg 2-1/2 HOURS of installing content! :ahhh: :ahhh: :ahhh:
    But it's done! :cheese: AllDaz metadata files I could find, Real MEtals, Bazaar 1, dynamic cloth control and dynamic stuff, and pw plugins all up and operational! Heh, heh, heh! Look out world! :snake: :vampire:
    I'm liking 4.6 more and more, the more I use it. The UI is FAR better suited for a laptop than Posers. :blank:
    Now to paste some tats on poor, unsuspecting Mike! :vampire: :vampire:
    Run Mike!! :lol:
    yayy it finished rendering. hmm 4.5 mbs, will have to divvy it
    http://www.daz3d.com/elven-nymph
    http://www.daz3d.com/the-songstress
    Great Misty :)
    I need to get back into rendering.
    *waves* Me too. Been a little ill, moar better nao :)
    Laptops hard on the eyes hey :) Been playing with fire heh
    674 x 586 - 241K
  • OdaaOdaa Posts: 1,548
    Well, I managed to redo the materials for Xurge's Enforcer outfit (the texture expansions) to where in DS3A it actually looks sort of like his promos. That was a lot of trial and error.
  • RezcaRezca Posts: 3,393
    edited May 2013
    Hulloooo there :D
    Hah... *ahem* and yeah it does appear to be a subdivision issue , like the others have mentioned. Not enough subdivisions and the cloth will be very crinkly and not smoothish.
    As for passing through some body parts and not others, I have no idea. That rarely happens in C4D unless a Cloth Collider tag wasn't properly set up.
    This too. The collider object (The dragon and bed in this case) needs to have enough subdivisions as well in most cases.
    Post edited by Rezca on
  • kyoto kidkyoto kid Posts: 42,351
    ...first, being unemployed I do not have the resources to afford that.
    Second, it means having to find someone with a vehicle as I do not drive to lug the main box to a repair shop (which are all on the outskirts of town and which I have no idea of how reputable they are).
    Third in order to do this, it would mean wiping everything from the drives to have Win7 reinstalled. This means nearly another two months installing everything and setting up my runtimes and libraries all over again, and having to rebuild all my characters from scratch (as well as losing all the scenes I am currently working on).
    ...that is making this look like a lost cause.
    edited May 2013
    Kyoto Kid said:
    ...first, being unemployed I do not have the resources to afford that.A re-install of the OS from disk would cost LESS than many of your nights out you post about.
    Then find a person local, Hm.. maybe one of the Pub's you seem to enjoy, who knows how to install the OS, and then buy them a few rounds?
    Third in order to do this, it would mean wiping everything from the drives to have Win7 reinstalled. This means nearly another two months installing everything and setting up my runtimes and libraries all over again, and having to rebuild all my characters from scratch (as well as losing all the scenes I am currently working on).Nope, it means the OS can be installed to your drive but set up properly (might do a few file drops not already done but not enough to matter). Nothing would be lost except the Reg settings for the programs you have installed. A re-install fixes that, then MOVE all the content from the folders not allowed, and just point the programs to the proper folders. I have used Win7 re-install twice and never lost a thing. Now, all that said, if a real IT Tech looks at the PC and goes ???? you might be in deep do do.
    I'm sorry if you see my posts as anything other than me wishing you had no problems. But that is all I want. I have never had the problem you have and I'm using the very same stuff. I want you to enjoy it as much as I do.
    Post edited by Jaderail on
    Hulloooo there :D
    Hello! Still no idea how to work this blog thing, but giving it a try!
    The subdivision makes sense, it needs more polygons to hit (if Im understanding this right).
    Subdivide any mesh that does not have a high enough mesh count for Dynamic collision’s. The Dynamic controller can not calculate against low mesh items.
    That makes sense, but what about the trex face? Only half of it caused of a collision.
    I don’t know if it did work in 4.5. I got 4.6 a few days ago, and the dynamic sheet last night.
    I hope I did these quote things right, wouldn't want to post three different posts when I can just do one...
    it looks like a flower :)
    edited May 2013
    way passed sleepy time. no more calling in sick days, hazzz to work tomorrow. that's my plaint!
    it's been a renderpalooza weekend.
    render drop - Skimpwear envy :)
    suranian priestess outfit
    space dweller suit / cosmic textures
    oh nohs fingers poke thru, sighs, back to the renderingboard.
    850 x 850 - 289K
    Post edited by Mistara on
    edited May 2013
    ...bah, all this has been one royal pain in the bum and I apologise.
    I expected things to improve once the new system was finished. Apparently my ineptitude at configuring an OS has made a mess of something that I hoped would finally allow me to realise my ideas. When I checked a while back into having a fully tested professional install performed it really was more than I could afford (more than a good number of nights down at the corner gin joint). A co-worker took her system to one of those "inexpensive" shops, and they messed her system up worse than it was when she took it in.
    There are others I know of who had similar situations occur while trying to save a few zlotys. No, "bargain basement" IT techs are a bad idea.
    Reputable licenced shops charge, because they have more important corporate customers they work with rather than some old luddite who only wants to make pretty pictures on a computer.
    I'm going try one manual uninstall and reinstall of both 3Advanced and 4.5, heck may as well install the newest update as several have said it was more stable than the current release version.
    Post edited by kyoto kid on
    Yes is a sim rather than an effect so is like looking into a fire for real - not necessarily a good thing if you want something in particular :lol:
    Nothing more aggravating than when computer says no :lol:
    Hey great :)
    looking forward to that :)
    I'm clearly better than I was, but feet still want to go in a direction opposite to the rest of me for some reason. That is my complaint.
    I can (barely) recall playing a video game that had these in it. It was an RPG, but I can't remember the name.
    http://www.daz3d.com/new-releases/the-treasure-beast
    It's got tentacles so Wooly will want one. :lol:
    Just the temperature of a ball and a disk, no turbulence at all
    671 x 686 - 37K
    That's some treasure :lol:
  • SkirikiSkiriki Posts: 4,976
    Well in D&D, mimics often like to pretend being treasure chests, so they can nom on adventurers...
