Black / dark eye brows
I have a strange issue where Black / dark eye brows, turn grey when I render, in Iray.
I also have inconsistent results when I need eye brows to be orange or red.
Welp!
  • Are they fibermesh brows? I'd suggest at first blush turn off translucency.
  • I am not sure if it is Fibermesh brows.  I have taking a strong liking to Victoria 4.2
    It will depend on the lighting. People's hair looks different colors in different types of light. That is normal.
    Also if you are rendering Victoria 4.2 then you are likely not using fibre mesh brows. I've noticed V4/M4 hair often turns out glossier in iRay than 3DL because the people that modeled the hair for 3DL made it glossier than it should be so that it would render faster in 3DL.
