Texture problem
in The Commons
Hello,
Texture problem with bear prop. That how it looks. What it can be?
The set is Solitaire by meipe.
Thanks in advance.
Hello,
Thanks in advance.
Does it look right in 3Delight? I seem to recall, from previous discussions, that the set uses custom 3Delight shaders which don't translate automatically to Iray. Edit: Which seems to be confirmed by https://www.daz3d.com/forums/discussion/90471/solitaire-by-meipe-bear-mats-solved-pretty-much/p1
Thanks for your respond. I didn't try it in 3dlight , cause I need it in Iray
So if get it correct, I should apply Iray fur shader and the bear become like on picture?
