Texture problem
in The Commons
Hello,
Texture problem with bear prop. That how it looks. What it can be?
The set is Solitaire by meipe.
Thanks in advance.
908 x 903 - 107K
900 x 900 - 1M
270 x 351 - 21K
Does it look right in 3Delight? I seem to recall, from previous discussions, that the set uses custom 3Delight shaders which don't translate automatically to Iray. Edit: Which seems to be confirmed by https://www.daz3d.com/forums/discussion/90471/solitaire-by-meipe-bear-mats-solved-pretty-much/p1
Thanks for your respond. I didn't try it in 3dlight , cause I need it in Iray
So if get it correct, I should apply Iray fur shader and the bear become like on picture?
