G8 Morphs to G3
Hi all!
I know much has been written andsaid about transfering morphs from G3 to G8. But how about the other way around?
Can you transfer morphs from G8 to G3?
Thanks a lot,
Me
Post edited by gibrril_fa945a6cee on
Hi all!
Thanks a lot,
Me
And how does that work? I have a tool from DeviantArt that does the actual conversion for me. All I do manually is zero the G3 figure, set it to base resolution, dial in the morph I want exported and save that as OBJ. Then the tool converts that into a file that I can use on G8 using the morphloader pro tool. How do you manually convert a G3 morph or a G8 morph?
Thanks a lot,
Me
https://www.daz3d.com/forums/discussion/176271/morphs-from-g3-to-g8/p1
Thanks a lot!!!
Has anyone tried this? I'm curious if there's any distortion around the eyes/mouth or fingernails given the difference in the geometry.
It's no worse than with G3-G8 which is to say fairly good in most cases but if you were to sell the morph you would want to touch up a few things.
