Mesh Smoothing Setting in Daz Studio 4.10
in The Commons
Hi all!
I'm trying to convert some morphs from G3 to G8 and according to the instructions, I have to set "mesh smoothing to off". But I can't find a setting in Daz Studio that is called "mesh smoothing". Does anybody know where to find that setting in Daz Studio 4.10, or what it's called in that version?
Thanks a lot and Happy New Year,
Me
Select your figure at the base node and expand the General category in the properties tab. It should be under there.
Thanks for the reply! It's not there. I can find a couple of settings on Subdivision, but nothing called "Mesh Smoothing. Closest I get is "Subdivision Normals" where I can pick either "smoothed" or "preserve cage" as value.
Thanks a lot,
Me
Mesh Resolution (in the Parameters pane) Resolution Level set to Base? Or perhaps mesh Smoothing, but that will be present only if the model has a Smoothing Modifier applied.
Thanks for the reply! The level is set to base. So if I don't see the "mesh smoothing" paraeter, that means there is no smoothing modifier applied?
So do I have to apply a smoothing modifier and then set that to "off" or "0"?
Thanks a lot,
Me
No if it isn't there leave it alone.
Thanks for the reply! I'll leave it alone.
Thanks a lot,
Me.
