I want to re-install DAZ 3D 4.6 and all my content...
leo04
I want to reinstall DAZ 3D and all my content. My question is how do I go about doing it.
When I began I was just looking to use the DAZ I just installed it and some other content and used the instructions to add it to the Library.
Can I unload everything and use the DAZ Installer to reinstall everything?
Has anyone ever done this before? How does it work? Does it work? I have had no trouble using it.
Would appreciate any help on this anyone can give me.
B
The DAZ3D Install Manager won't install the DS application itself, but has almost everything else now. Make sure the install location matches the one in DS -- the default used by DIM is different from the old DS default location. I don't know if DS4.6 uses the new location, as I did an upgrade so it kept my old settings.
It does not I was told, so setting the paths in DS or the DIM is needed. I just did a Full clean install not long ago. I left the DIM to the new default as it is recommended for better function and just Pointed my DS to that path. Was easy to do.
Remember for a FULL clean install the Hidden Win7 folder AppData should be cleared of any and all DAZ 3D 4 folders (only do this after uninstalls). Also the CMS uninstalled and all folders deleted.
What about Windows 8?
Seems I am back here again. I am left with the delema of installation but Installation Manager or Connect.
Which is the better way to go here?
Daz Install Manager.
Is there a link to hard data on this? I prefer not to put anything on C:\ except Windows.
I would never have DIM install Gigabytes of content to my C drive SSD. It would overflow in no time. I have DIM install my content on an internal HDD. It works fine.
So your saying not to use the Connect install function? Only DIM?
Yes. That is my recommendation, based on numerous problems I have had with Daz Connect. I have used Daz Connect for almost everything, because I like the graphical interface and integration with Daz Studio. However, I have lived to regret it. I often think of uninstalling everything and starting over with DIM. But I keep thinking Daz will fix the Daz Connect bugs. For the most part, they have not. These are some of the Daz Connect design limitations and some of the bugs/issues I have reported and still suffer from:
If I were starting over today, I'd use DIM.
Thank you for the information. I tend to agree that DIM is a better way to go, however I still find that until I go back an install with Connect the asset did not install or it can't be found.
Have you found this to be true?
Oops. I just re-read your reply and I think I found the answer in Point #6.
I've never had an asset that I installed with DIM not show up in the Daz Studio Content Library. It is very important to be sure that the library that DIM is installing your content into, is mapped as a library to be used in Daz Studio. You do that in Daz Studio with the Content Directory Manager. You want to map the library for both Daz Studio Formats and Poser Formats generally. If you don't do this, none of your DIM content will show up as installed. Is this your problem, do you think?
You don't want to install the same product with both DIM and Daz Connect. That will duplicate the files on your computer and waste Gigabytes of disk space. If a product is installed with both DIM and Daz Connect, the Daz Connect version will be used. So if you have a problem with a product installed with Daz Connect, it is not good enough to just install with DIM. You must uninstall that product with Daz Connect first.
I often see this "install to C, it's better that way" being preached as gospel, but never with any hard evidence to support that claim. FXPansion was the only company that bothered to give details with regards to their BFD program. Content can be anywhere (and runs better when it's not on the same drive as the main program), but the program itself does function better when it's on C:\. I had it on a physically separate internal 500GB drive (F:\) and the content on another physically separate internal 500GB drive (G:\), and it ran great until I tried to render the tracks, and the cymbals came out with gaps in the sustain. Reinstalled to C:\ and that problem went away.
However, I'm not seeing any hard data that DS runs better, renders faster, or anything else to convince me to install it on C:\.
I have the Daz Studio program installed on C, but not any of the content files.
Using the Install Manager, I have decided to install on my :"D:\drive"; The path I have selected is D:/Users/Public/documents/My DAZ 3D Library/....this path is the same as the default only on the "D:\" drive.
I now have a question, for Content Updates there are two options. Install to Respective "Installed" Paths. and Intall to Selected Path.
MY QUESTION IS THIS:
What is the difference between these two options and why is one better than the other, if it is?
Thanks.
P.S. Just thinking, is there a tutorial anywhere that would explain, in detail, the use of Install Manager?
Install to respective isntalled paths isntalls any updates to the content directory that the item was first isntalled to, Install to selected Path isntalls to the current install folder even if that is not the same as the oen used for the product's initial install - which is useful if you have moved your content.
Here is a link to the Install Manager documentation.
