Is bulk removal of highlights from shaders possible ?
0oseven0oseven Posts: 626
It's common clothes and other models opened in Carrara often look like plastic so one has to remove highlights and shininess from the textures in the shader room.This is a bit of a pain especially locating the offending items.( which mostly is all)
So I'm wondering if there is a bulk method of applying changes . ( a one click solution would do :) )
Would Fenric's Pose and Shader Tools plug in do it or be of any help ?
http://www.daz3d.com/pose-and-shading-tools-2
  • HeadwaxHeadwax Posts: 9,927
    hi
    you need this
    http://fenric.com/wordpress/store/products/poser-shader-doctor/
    Fenric is a genius
    at the moment its 15percent highlight but he has promised to make it user adjustable
  • evilproducerevilproducer Posts: 9,040
    Don't forget, manually or with a plugin, once your adjustments are made, you can save the shader to the browser, or even the entire object/character itself. The object/character will even load faster from the browser because it's in the native .car format!
  • 0oseven0oseven Posts: 626
    Wow That Fenric IS a genius !!
    I really didn't expect a solution - thanks Headwax for that pointer and thanks Fenrick for the plugin.Appears to be exactly whats needed and at $2.50 it's a bargain.l
    EVIL
    Yes I do save my characters as car files fully clothed. As you say Evil, they load very quickly and of course it saves applying clothing again also it's easy to add/exchange clothing.
    thanks everyone
  • araneldonaraneldon Posts: 712
    Fenric is a genius
    He appears to have updated the plugin already, check the product page.
    Thanks!!
  • ManStanManStan Posts: 0
    For figures I set the shader, mostly with simply drag and drops then save the multichannel shader. So for figures I have shaders all ready. Drag/drop/done. Clothes are usually easy because they don't have many shader zones. The only time this is burdensome to me is with big prop scenes like stonemason's. But then I like working with shaders ;)
    I downloaded and can confirm the updated version defaults to preset but hold shift down whilst selecting shader doctor and menu pops up allowing percentage selection for highlight/bump/shininess settings.
    Operates on selected items only which is handy too.
    My request for one click solution was a joke but thats what I got :coolsmile:
    thanks again all.
