dForce help - can't add a modified from object-geometry dropdown menu
Ok.. So latest version of 4.10  - wanted to try dForce, and though a simple plane draping over a sphere might be an easy way to try it out. I can create and pose the primitives, but I do not have the "Edit/Object/Geometry/Add dForce Modifier: Dynamic Surface" showing at all in the deopdown main menu... I do see the create dforce modifer weight node option under the create menu..
 Any ideas would be most welcome..
Thanks!
  • Have you run the update menus script?
    Rather than using the script, which is present for now but may not be in future, use the Window>Workspace>Update and Merge Menus command which seems to be a more integrated version.
  • hacsarthacsart Posts: 2,034
    That did it...
    Thanks all!
