dForce help - can't add a modified from object-geometry dropdown menu
hacsart
in The Commons
Ok.. So latest version of 4.10 - wanted to try dForce, and though a simple plane draping over a sphere might be an easy way to try it out. I can create and pose the primitives, but I do not have the "Edit/Object/Geometry/Add dForce Modifier: Dynamic Surface" showing at all in the deopdown main menu... I do see the create dforce modifer weight node option under the create menu..
Any ideas would be most welcome..
Thanks!
Have you run the update menus script?
Rather than using the script, which is present for now but may not be in future, use the Window>Workspace>Update and Merge Menus command which seems to be a more integrated version.
That did it...
Thanks all!
