mcjJet script: basic particle effects for DS 1-4 - with Burst mode!
2
    Casual said:
    It's from the link in the first post that one gets the page 404.
    THANK YOU! Looking forward to playing with this one.
    I have noticed with interest this phrase ... I might borrow it sometime ;-)
    To avoid incomprehensible effects ...
    welcome !
    thanks i corrected the link ( which was merged with the word "so" )
    np, Works now.
  • RAMWolffRAMWolff Posts: 10,373
    Thanks so much. I was trying the link on the first page. I'll download when I get home from work.
  • mCasualmCasual Posts: 4,607
    edited August 2014
    important update and fixes
    the DS1/DS2 versions had become non-functional
    fixed
    it still worked for DS3.0 and DS4
    but not for DS3.1
    actually it didnt work well anymore with DS 3.0 and DS4, the emission didnt happen at the position of the emitter
    but now it does !
    you can make great particle effects with it
    tip: to increase the smoke/particle flow, create your particle animation at a frame rate like 150fps
    then set the FPS back to its normal rate, like 30 fps
    and you get a 5X flow
    https://sites.google.com/site/mcasualsdazscripts/mcjjet
    1000 x 1000 - 468K
    512 x 512 - 411K
    Post edited by mCasual on
    edited August 2014
    for this 30 frames animation ( which could be directly used in video compositing , take it )
    loaded a 60-billboards figure
    i created a vertically standing cylinder
    set the timeline's FPS to 120 FPS
    the playrange from 0 to 120
    selected the cylinder
    launched mcjJet
    adjusted the settings as you see below
    it's the [Default Settings] but a narrower spread, 5 degrees and the end of simulation is at frame 120
    ran the script
    changed the frame rate back to 30 fps
    X-Scaled the hole billboard figure for a narrower jet
    changed the opacity maps for all the panels to the one shown in fig 3 ( take one! : ))
    512 x 512 - 38K
    585 x 507 - 114K
    600 x 600 - 704K
  • atticanneatticanne Posts: 3,009
    Oh, what fun. Thank you very much. I'll play with this when I take a break from my programming class.
    next version will probably have the color gradient option
    600 x 600 - 850K
    edited August 2014
    sodium flame color gradient, software render
    ( next version of mcjJet )
    both the ambient and the diffuse color of each "particle" are animated
    but there's still a small looping quirk to fix
    fig 3, a 30 frames, 30 panels animation with precise looping .... almost
    480 x 480 - 461K
    480 x 480 - 24K
    480 x 480 - 409K
    edited August 2014
    there ya go, perfect looping 30 frames. 30 billboards
    ( twas a case of division-by-zero )
    did you know virtualDub can load animated gifs? now you know
    the animated gifs on this page are copyfree
    480 x 480 - 547K
  • IvyIvy Posts: 7,165
    wow that incredible.
    does it work in daz 4.6?
    it's supposed to work in 4.6 yes, but the color-ramp effects are not included
    they should be soon
    there's all sorts of issues to fix, like the rotations of the billboards, which strive to always face the camera
    800 x 800 - 539K
    I absolutely love these flames. They're great.
    edited September 2014
    today i should fix the billboard/panel orientation issue and post the new version with the color-ramps/gradients
    the panels always face the camera which is good, but they always stand up, this was good for billboard-trees but not for rocket flames
    1920 x 1080 - 237K
    800 x 800 - 91K
    getting there ...
    i didn't remember it but mcjJet already supported 3 types of billboard face-the-camera options
    640 x 360 - 364K
    1920 x 1080 - 378K
  • SimonJMSimonJM Posts: 6,085
    Casual said:
    getting there ...
    Doncha just hate it when you can't remember how cunning you have been! :)
    the new mcjJet will have improved billboards-face-the-camera processing
    sometimes when the camera was moving in relation with the planes, they did strange flips
    videos using mcjJet
    https://www.youtube.com/watch?v=1ZLmLpprLSg
    http://www.youtube-gir.com/user/mcasual
    640 x 360 - 556K
  • RuphussRuphuss Posts: 2,631
    I like your steampunkettes video
    looks like you are using a lot of scripts there
    and .. you really have your own style...I like that
    though I am not Bob (or God)
    there will be a color-ramp selector for the ambient color
    and one for the diffuse color
    maybe one for the opacity (fade out ) effect which is presently directly proportional to the "age" of each emitted particle
    and using your own color ramp will be as easy as saving a 32x256 pixels jpeg image in mcjJet's "colorRamps" folder
    960 x 540 - 42K
    960 x 540 - 71K
    683 x 535 - 137K
    298 x 276 - 21K
    300 x 300 - 15K
    tomorrow i publish the new mcjJet with color ramps, i just want to make it a bit more fool proof
    ah i think i understand now ....
    seen from Amy's point of view
    the billboards are narrow vertical strips of light,
    that's why they don't illuminate her much
    i'll try cone-shaped particles
    fig 2 : using a 4-panels-per-particle figure
    Blender-Cycles is not really suited for scenes with concentrated light sources
    960 x 540 - 78K
    960 x 540 - 45K
    600 x 1000 - 85K
    if you scale the billboard figure before computing the particles animation, you can get stroke/line shaped particles
    485 x 800 - 153K
    291 x 479 - 189K
    1280 x 720 - 89K
    600 x 337 - 826K
    Wow! Impressive.
    SimonJM said:
    Wow! Impressive.
    i'll do a few tests in DS4.6 ( doing most in DS3 )
    and post it today if all goes well :)
    485 x 798 - 107K
    485 x 798 - 83K
    DS 4.6 tests underway !
    and i fixed the offset function, which was used to move the emission point at the top of the cone
    fig 2 - UI resizing because pixmap.resize crops instead or resizing
    fig 3 smoke'ish
    600 x 382 - 389K
    665 x 538 - 116K
    948 x 605 - 185K
    tested in Daz Studio 2.3 and 1.8
    for people still using their 386sx
    kidding kidding, i meant 66MHz 486 beast
    1920 x 902 - 371K
    mcjJet 2 is now on the net !
    tomorrow i'll update the manual
    i decided to leave the old mcjJet be
    and added mcjJet 2
    in case there's backward compatibility issues or something
    one important point to note is that the script comes with a subfolder containing some color ramps
    you can create your own as long as they are in jpg format and are 256 pixel wide
    oops i now see the thumbnail for the ds1 version is 800x800 :) don't think it will cause problems
    500 x 500 - 77K
    91 x 91 - 9K
    mcjJet 2 update !!
    while writing the manual, i discovered the burst mode's final fade-out phase was not there anymore
    so if you downloaded mcjJet2 last night or this morning, better re-download it
    also note that mcjJet2 will soon have its own web page / manual
    and it will be at https://sites.google.com/site/mcasualsdazscripts4/mcjjet2
    240 x 153 - 189K
  • Mustakettu85Mustakettu85 Posts: 2,933
    Amazing! Thank you very much!
    * p * i * x * i * e * d * u * s * t * p * i * x * i * e * d * u * s * t * p * i * x * i * e * d * u * s * t
    The new mcjJet 2 with color-ramps lives here :
    also a new 360°billboard figure and a new cone-shaped opacity map for the billboards
    This is pretty darned awesome Casual. Thanks so much! :-)
    thanks for your nice tool
    both links give a 404 response
    for complicated and richer effects search the Daz3d.com store for the word "particles"
    http://www.daz3d.com/i.x/search/searchsub/?_m=d&sstring=particle
    and the vendor "Nerd3D"
    http://www.daz3d.com/i.x/search/searchsub/?_m=d&sstring=nerd3d
    hello casual
    would it be hard to make a script for "ctr-d" for an animated range ?
    I always do this frame by frame and that's not fun
