Daz Studio 4.10 crashes on loading.
peteVaultpeteVault Posts: 308
I have done a search on Google and have searched on these forums...but I can't find an answer to this problem. I can run 4.9 easily on my older machine (alienware R17, GTX680m video card, Win 7)...but when I install Daz 4.10, the program crashes and doesn't load....even 4.9 won't load, unless I remove both and re-install. I have my laptop up-to-date...including the latest drivers for my nvidia. If someone knows of a helpful link that would be great. Thank you, in advance, for your time and advice.
Post edited by peteVault on
  • Pantros2Pantros2 Posts: 103
    You mean 4.10, right? 4.1 was a couple years back. This isn't decimals 4.10 does not equal 4.1
    Yes....4.10
  • What are you system specifications? If you install the Public Beta (via DIM) will that launch?
  • peteVaultpeteVault Posts: 308
    edited December 2017
    Intel(R) Core(TM) i7-3840QM  CPU@  2.80GHz
    RAM 32GB    64 bit operating system  Win 7 Ultimate
    GeForce GTX 680M 388.71
    Via DIM Yes I tried that...same result.
  • No obvious, to me, red flags there. Go to C:/Users/YOU/AppData/Roaming/Daz 3D/Studio 4 and open the log.txt file (AppData is a hidden folder, so you will need to enable the display of hidden files and folders). What are the last few lines of that?
  • I looked over the log....but there is nothing refering to anything since I un-installed 4.10 and re-installed 4.9. The log only references the latest render since I re-installed. I'd have to re-install 4.10 to see the failure. I'll wait until I'm forced to use it. Thanks for your suggestions.
