Daz Studio 4.10 crashes on loading.
peteVault
I have done a search on Google and have searched on these forums...but I can't find an answer to this problem. I can run 4.9 easily on my older machine (alienware R17, GTX680m video card, Win 7)...but when I install Daz 4.10, the program crashes and doesn't load....even 4.9 won't load, unless I remove both and re-install. I have my laptop up-to-date...including the latest drivers for my nvidia. If someone knows of a helpful link that would be great. Thank you, in advance, for your time and advice.
637 x 479 - 106K
528 x 160 - 42K
Post edited by peteVault on
You mean 4.10, right? 4.1 was a couple years back. This isn't decimals 4.10 does not equal 4.1
Yes....4.10
What are you system specifications? If you install the Public Beta (via DIM) will that launch?
Intel(R) Core(TM) i7-3840QM CPU@ 2.80GHz
RAM 32GB 64 bit operating system Win 7 Ultimate
GeForce GTX 680M 388.71
Via DIM Yes I tried that...same result.
No obvious, to me, red flags there. Go to C:/Users/YOU/AppData/Roaming/Daz 3D/Studio 4 and open the log.txt file (AppData is a hidden folder, so you will need to enable the display of hidden files and folders). What are the last few lines of that?
I looked over the log....but there is nothing refering to anything since I un-installed 4.10 and re-installed 4.9. The log only references the latest render since I re-installed. I'd have to re-install 4.10 to see the failure. I'll wait until I'm forced to use it. Thanks for your suggestions.
