Adjusting th e push modifier
reelyorreelyor Posts: 237
How does one adjust the amount of "push" in the push modifier? I can select the clothing item, and then when I select the push modifier, the item ends up a larger distance from the surface of genesis than desired.
  • SloshSlosh Posts: 2,391
    After you apply a push modifier, a new entry will appear in the parameters tab called mesh offset. The default is 1.0 which is usually way too high. Try setting it to about .2
  • OstadanOstadan Posts: 1,130
    Units are cm, right? So .2 is 2mm?
  • Richard HaseltineRichard Haseltine Posts: 109,252
    Yes.
  • reelyorreelyor Posts: 237
    I was abke to use the tool easily. Thanks - it went fine.
    You are right - the 1.0 setting is way off. I went down to .5
