Sasquatch - Render looks "smudged"
I have posed and rendered the Yeti LAMH preset that came with the Sasquatch product.
What I noticed is the "smudged" hair (especially around the head / face), where you no longer can distinguish any individual hair-structure, but rather just a grey smudge ...
Does anyone have any clue as to what is causing this ?
Are there any special render settings that have to be considered ?
Cheers,
Andreas
Lower the Shading Rate in the render settings.
Well, that does help (sort of), but does not eliminate the problem.
I even went ahead and tuned it down to 0.01, but still get "smudging" ... and to quote a good friend of mine:
"That sucketh" :-/
Any other ideas of what else might help ?
I don't mind experimenting with various settings, but I'm lost because I do not understand the problem, only its symptoms.
Cheers,
Andreas
What are your pixel samples set to? They also play into how SHARP a image is.
What kind of lighting are you using?
I know I have had issues with garibaldi and lamh hair under certain lights. You may want to look into the LAMH threads to see what the best lighting setup is. I know there was alot of discussion on that.
Rawn
